20 Most Recent
Konica KL-3015 Plus Laser Printer Questions & Answers
Error code c-3401 on konica c1070
Hi!
The C-3401 error code on the Konica Minolta C1070 typically indicates a fusing pressure release failure. Here are some steps you can follow to troubleshoot the issue:
- Turn off the printer and unplug it from the power source.
- Wait for at least 10 minutes to allow the fuser unit to cool down.
- Open the front door of the printer and remove the fuser unit.
- Check the fuser unit for any damage or signs of wear and tear, such as cracks or scratches on the surface. If you find any damage, you may need to replace the fuser unit.
- Check the pressure release mechanism inside the printer to ensure it is working correctly. The pressure release mechanism should be able to move up and down freely.
- Reinstall the fuser unit and ensure it is correctly aligned.
- Turn on the printer and check if the error has been resolved.
If the C-3401 error persists, it is recommended that you contact an authorized Konica Minolta service technician for further assistance, as the issue may require replacement of parts or other more advanced troubleshooting.
Regards
C-3303 error konica how to fix?
The C-3303 error on a Konica copier typically indicates a problem with the cooling fan. Here are some steps you can take to try and fix the issue:
- Check the fan: Open the copier and check the cooling fan to see if it's running properly. If it's not, check for any obstructions that may be blocking it or any loose connections.
- Clean the fan: If the fan appears to be running but the error persists, it may be dirty and in need of cleaning. Turn off the copier and unplug it before attempting to clean the fan. Use a soft brush or compressed air to remove any dust or debris that may be clogging the fan.
- Replace the fan: If the fan is damaged or not functioning properly, it may need to be replaced. Contact your Konica technician or authorized service provider to order a replacement fan and have it installed.
- Reset the error code: After addressing the issue with the cooling fan, reset the error code by pressing the "Function" button followed by "Clear" and then "Err". Enter "OK" to clear the error code and restart the copier.
If none of these steps solve the issue, it may be necessary to have a professional technician diagnose and repair the copier.
How to solve konica 3070 error C-6102?
I strongly believe you can fix the C-6102 error code by the following;
The C-6102 error code on the Konica Minolta Bizhub 3070 printer is related to the fusing unit. The fusing unit is responsible for melting the toner onto the paper to create a permanent print. When the fusing unit becomes damaged or is not functioning properly, it can trigger the C-6102 error code.
To resolve the C-6102 error code, you can start by checking the fusing unit for any visible damage or wear. If you find any, you will need to replace the fusing unit. However, if the fusing unit appears to be in good condition, you can try cleaning it to see if that resolves the issue.
To clean the fusing unit, you will need to remove it from the printer and then clean the thermistor and the thermistor sensor. The thermistor is a small resistor that measures the temperature of the fusing unit, while the thermistor sensor is a device that reads the output of the thermistor. Over time, dust and debris can accumulate on these components, which can cause the fusing unit to malfunction.
To clean the thermistor and thermistor sensor, you can use a dry cloth or compressed air to remove any dust or debris that may have accumulated. Once you have cleaned these components, you can reassemble the fusing unit and reinstall it into the printer.
After you have cleaned or replaced the fusing unit, you can power on the printer and check if the C-6102 error code has been resolved.
Dear friends I have 4070 Konica I have issues controller unconnected and it's take initial long
The issue you are describing with your Konica Minolta 4070 copier may be caused by a problem with the copier's controller board. The controller board is responsible for coordinating the various functions of the copier and communicating with the other components. If the controller board is not working properly, it can cause the copier to take a long time to initialize and may display an error message indicating that the controller is disconnected.
To troubleshoot this problem, you can try the following:
- Check the connections between the controller board and the other components of the copier to ensure they are secure and not damaged.
- Check for any loose or damaged cables and replace them if necessary.
- Check the power supply to ensure that it is providing the correct voltage to the copier.
- Check the firmware or software of the copier to ensure that it is up to date and compatible with the controller board.
- If the problem persists, it is recommended to consult a professional technician to check the copier, or contact the Konica Minolta customer service for assistance.
It is important to note that these instructions may vary depending on the copier model, so it is best to consult the user manual for specific instructions.
Konica r2 large print then 381
The error code 381 on a Konica R2 Large Print device typically indicates a problem with the developer unit. The developer unit is responsible for adding toner to the printed image and when it fails, it can cause the error code to appear and the printer to stop working.
Here are a few steps you can try to troubleshoot the issue:
- Check the developer unit for any debris or buildup that may be blocking it. Clean the developer unit with a soft, dry cloth.
- Check the developer unit's connector for any damage or debris that may be preventing it from making a proper connection with the printer. Clean the connector with a soft, dry cloth.
- Check the developer unit's gears and make sure they are not jammed or damaged.
- If the above steps did not resolve the issue, it may be necessary to replace the developer unit.
It's important to note that this is a complex issue and it's best to have a professional technician diagnose and repair the problem to ensure proper and safe operation of your printer. It's also important to check the manual or contact the manufacturer for more detailed instructions or troubleshooting steps, because the code 381 could have a different meaning on different models or brands.
Konica ubix 1015
F 35
Fuser issue (Hot part) replace the unit and reset the code on the machine. Though service mode 25.
