20 Most Recent Coby CVM225 Bluetooth Headset Questions & Answers
How do I connect my coby bluetooth to my
Start with the headset turned off. Then, press and hold the Multifunction control for 8 seconds, until the blue and red lights flash alternately. It is now in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, 'CV-M225' will appear in the phone' screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If pairing is successful, the headset will enter the stand-by mode.
By the way, in case your headset's user guide happens to be missing, feel free to download it from this location.
Hope it works for you.
Cheers! Carlos
5/14/2010 9:19:14 PM • Coby CVM225... • Answered on May 14, 2010
How to hook this up to cell phone
well on your phone go to settings and go to headset and go to auto answer and turn it on thats howi got mine to work it might and might not you probly got a differ phone
4/25/2010 7:01:28 PM • Coby CVM225... • Answered on Apr 25, 2010
0answers
How to pair
Be the first to answer 1/3/2014 6:15:01 AM • Coby Radio... • Posted on Jan 03, 2014Be the first to answer
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM • Radio... • Answered on Apr 19, 2024
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
The LED light display is not working on the face of detachable headset is there some button i can press to enable Firetail FT-8238D
I have the same problem. When o remove the interface the led is not flashing as per the instruction manual
3/27/2024 5:24:11 AM • Radio... • Answered on Mar 27, 2024
I need a manual for a TRONIC PLL 2023 radio. Can you help? Ray
http://www.manuals.group/results.php?search=TRONIC%20PLL%202023%20KURZ
3/26/2024 7:06:10 AM • Radio... • Answered on Mar 26, 2024
I have a Sonoff switch device which worked fine until I changed Broadband. Now the eWeLink cannot pair to the device??
Home - SONOFF OfficialSONOFF Official https://sonoff.tech Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!‎SONOFF Products · ‎Basicr2 · ‎ZigBee Bridge · ‎Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official https://sonoff.tech > product-review > tutorial > how-to-p... How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
3/24/2024 6:49:12 PM • Radio... • Answered on Mar 24, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please. Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity. https://www.google.com/search?q=KPG-790 ..
2/15/2024 3:06:45 AM • Radio... • Answered on Feb 15, 2024
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero. https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive https://www.google.com/search?q=KEM+P29923 ..
2/9/2024 1:12:05 AM • Radio... • Answered on Feb 09, 2024
New Motorola Mag One radio fully charged will transmit but will not receive. why?
This question edited for clarity. Contents of correction Question added here and Deleted. Did you read the Manual? It looks like it has Volume Buttons on the side and may be set to Zero volume? https://www.motorolasolutions.com/en_us/support.html https://www.motorolasolutions.com/en_us/products/two-way-radios/analog-business-radios/portable-radios/bpr40.html#tabproductinfo ..
1/18/2024 7:03:58 PM • Radio... • Answered on Jan 18, 2024
Pin for tzumi earpiece Bluetooth
i need a code for my ear piece
12/29/2023 7:49:36 AM • Radio... • Answered on Dec 29, 2023
I have an old Turner 253 mic & want to wire it to a road king 5640.Wires coming from microphone are shield ,white,green & black.?? 5 wires,4 pin?e
See following diagram. I think it is carbon type microphone and seems same as required by you. Wire color codes are Black and Red are switch to enable audio circuitry on remote device (Push to Talk Switch, Usually in transmitters), White and Green are audio signal and shield. Print 51.TIF (2 pages) (mypicsonline.net) Roadking 5640 require dynamic type microphone. Radio Code Definitions; Specifications - ROAD KING RK5640 Owner's Manual [Page 17] ' ManualsLib
12/15/2023 2:14:05 PM • Radio... • Answered on Dec 15, 2023
I have a Motorola MCS2000 Model 2 and I need to know how to factory reset this radio, and also where can I get the CPS.
Question edited for clarity, add maker and toss in some CAPS. The site does not do well on abbreviations 'CPS' - Customer Programming Software? https://www.google.com/search?q=mcs2000+UHF+2+CPS https://www.google.com/search?q=Motorola+mcs2000+UHF+2+reset+button ..
12/8/2023 3:36:13 AM • Radio... • Answered on Dec 08, 2023
What it the wiring for a D104 mic to president cb?
It depends on what model.
11/29/2023 11:20:13 PM • Radio... • Answered on Nov 29, 2023
Coby CVM225 Bluetooth Headset Logo
4 questions posted
Top Coby Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Coby Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Radio Communications
Most Popular Question
connect coby bluetooth
  • Radio Communications
