20 Most Recent GPX C389B Clock Radio Questions & Answers
I can't figure out how to set the alarm and make
Hello Barb,
To set the alarm hold either alarm 1 or alarm 2 buttons down. While holding down the button adjust the hour by pressing the tune+ button. The bottom left of the display there will be a light letting you know if it is pm or am. While still pressing the alarm press tun- to select the minutes. If you want to wake with radio or a buzz keepholding the alarm button down and press the am/fm/aux button. Release the alarm button when done. To select an alarm just press the alarm botton you want once, a light on the right side of the display will turn on. To unselect press the same alarm button once and the light will turn off. To turn the buzzer off in the morning select power/al off button located at the top left of the unit.
7/8/2011 1:51:48 PM • GPX C389B Clock... • Answered on Jul 08, 2011
2answers
Downloading songs from itunes to the MP3 player
The GPX mp3 player is incompatible with iTunes (as are most non-iPod mp3 players). There are a few mp3 players out there that are iTunes compatible, but this is not the one.
-Tha Mp3 Doctor
11/18/2022 3:15:32 AM • GPX Audio... • Answered on Nov 18, 2022
3answers
Where can i go for free music for my gpx mw151p 4gb
i wouldn't recommend doing so (piracy is a crime) but there are some free services out there to get music just becareful of what you download from the internet
3/12/2022 11:10:03 AM • GPX Audio... • Answered on Mar 12, 2022
Brand new GPX mp3 player will not pair or show up on usb drive
Instruct the computer to search for it. The computer should automatically find it and load drivers, but it should show in Windows Explorer as a volume in the left pane. Where are you looking? It will only pair with a computer if the computer has Bluetooth and most don't. Pair with a smartphone. How do I transfer my music to my device? This device is capable of playing MP3 and WMA (4ithout DRM) files. To load files requires a computer with a USB connection and the minimum requirements of Windows XP .
  • Connect the player to the USB cable provided in packaging, and then connect the other end to your computers USB port.
  • Once connection has been made between the device and your computer, a "GPX" drive will appear in the computer directory.
  • Double click on the GPX drive
  • Drag and drop your MP3 files and folders into the Music or playlist folder
https://gpx.com/on-the-go/gpx-bluetooth-mp3-player-mwb308r.html ..
3/6/2022 8:42:20 PM • GPX Audio... • Answered on Mar 06, 2022
My gpx mw3837 isnt turning on?
RETURN IT TO PLACE PURCHASED AS DEFECTIVE .
1/7/2022 1:56:14 AM • GPX Audio... • Answered on Jan 07, 2022
I need the manual for GPX Model KCCD3004DP
There isn't one for that particular model https://www.google.com/search?q=gpx+model+kccd3004dp+manual ..
11/19/2021 8:28:37 PM • GPX Audio... • Answered on Nov 19, 2021
NEED Instructions or Manual for GPX Model HTMU3234....
Contact GPX or its distributor to determine availability and source.
9/6/2021 4:30:41 AM • GPX Audio... • Answered on Sep 06, 2021
2answers
Every time i try to
Many online music stores employ DRM to restrict usage of music purchased and downloaded online. The best way to overcome this is to download DRM- free tracks. Some online music stores such as amazon, eMusic and Beatport give you DRM free tracks. Try getting your music from them. Or else you can rip the Cds to get the tracks.
hope this solves your problem.
FixYa!!
4/9/2020 9:31:14 AM • GPX Audio... • Answered on Apr 09, 2020
Gpx s7050 cd open/close button not working. is there a fix?
Sometimes there's a small pinhole in the face of the door panel. If so, straighten a paper clip and press straight into the hole. That will press lever that pushes the slide outward. If no pinhole, try a case knife (table knife). Shove between the door panel and the casing, and try to pry it panel outward. Once, not too long ago a friend lost a CD. They were sure they put it into the player on the laptop. When removing the CD player, I found the CD laying atop the player casing, so either they shoved it in the crease between the player and the laptop casing, or it popped up as they were closing the door ind it was shoved int hat crease. Good luck.
3/21/2020 8:06:20 PM • GPX Audio... • Answered on Mar 21, 2020
Manuel for gpx 18" Wireless Sound Bar
This is a website for the soundbar. https://gpx.com/in-home/home-music-systems/18-sound-bar-with-bluetooth-wireless.html There is a pdf of the manual on the page Regards Geoff
1/8/2020 4:30:29 AM • GPX Audio... • Answered on Jan 08, 2020
How do I unlock the transit screw on the CD PLayer on my GPX Stereo Model S7799?
Most of those types of screws only require a 1/2 turn to unlock.
12/11/2019 8:48:35 PM • GPX Audio... • Answered on Dec 11, 2019
Had a GPX S7794 for years, now having trouble w/ turntable. Turns on by moving tone arm right, but if moved left to try to place it on a track towards the end of the record, turntable shuts off.
What happens is that a mechanical system under the turntable pushes on a micro switch to operate the motor. Clearly either the mechanical system has moved out of position or the switch has. You take the bottom off the turntable and see what happens when you move the arm.
10/19/2018 11:44:26 PM • GPX Audio... • Answered on Oct 19, 2018
Manuel or just how to operate it GPX Model KC 220s
I searched and couldn't find a manual. I found a free manual for a different model GPX that might be of some use. https://gpx.com/amfilerating/file/download/file_id/83242/ https://gpx.com/amfilerating/file/download/file_id/83242
8/11/2018 2:47:25 PM • GPX Audio... • Answered on Aug 11, 2018
Need remote codes for gpx hm3817dt thanks
First, I'm not a GPX reapresentative.* Check your warranty. Call for support.* User instructions; https://images-na.ssl-images-amazon.com/images/I/B1JjZHqCJCS.pdf* Customer help line; 888-999-4215 *** Following is for information only.**** Specs; https://www.bestbuy.com/site/gpx-micro-hi-fi-system-black/2878063.p?skuId=2878063* Amazon also supports this brand; https://www.amazon.com/GPX/b/ref=bl_dp_s_web_2529506011?ie=UTF8&node=2529506011&field-lbr_brands_browse-bin=GPX* Cnet review; https://www.cnet.com/products/gpx-hm3817dt/specs/* Another model review; https://www.youtube.com/watch?v=cJIx-x45LYQAloha, ukeboy57PS; If your using a 3d party remote (that must be GPX compatible)then the codes will be on the (remote)papers.
8/3/2018 10:24:32 PM • GPX Audio... • Answered on Aug 03, 2018
2answers
I need a manual on my C1550 gpx Karaoke
Whats rong w it
7/29/2018 5:20:47 PM • GPX Audio... • Answered on Jul 29, 2018
I have a GPX model CAS337B v 1902-01 cassette player with am/fm radio. When I play the cassette, there is no sound. What to do?
First check if the tape is moving during playback. If it is not there could be something wrong with the mechanism, such as a drive belt being off. If it is moving. Then it could be that a tiny leaf switch has become broken or bent cutting the sound off. Other issues include a faulty switch that controls the switching from the radio to tape. Could be just dirt in the switch. Or the pre-amp failure of the cassette player.
6/25/2018 10:48:56 PM • GPX Audio... • Answered on Jun 25, 2018
Where can i find a manual forthe gpx c1600 0308014007 duel cassette bw tv karaoke machine aug 2003 please ive been to gpx site but no help there
A 2003 model will be unlikely to be available except on eBay or in a second hand charity shop. Can you tell if this eBay vintage (meaning old...) model is the same one or not? Eventually, if you check eBay you find one with a manual. https://www.ebay.com/itm/Vintage-GPX-Karaoke-Machine-Dual-Tape-Deck-with-Microphone/152831786844?hash=item23957bff5c:g:mZoAAOSwk1haNniq Vintage GPX Karaoke Machine Dual Tape Deck with Microphone eBay
4/6/2018 2:57:30 AM • GPX Audio... • Answered on Apr 06, 2018
GPX C389B Clock Radio Logo
1 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
MegaByteMe
MegaByteMe
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
figure out set alarm make
  • Audio Players & Recorders
