20 Most Recent Redfield Revolution Riflescopes Questions & Answers
if you would give me the serial number i can try and get you the correct manual that you need
Redfield... | Answered on Nov 05, 2018
Redfield was purchased by Leupold in 2008, and is only able to repair and service Redfield scopes made in 2010 or later. If it was made before 2010, then it isn't covered by warranty, but Leupold does suggest contacting Iron Sight, Inc, if you want to ask about repairs and associated costs. Here's what the Redfield/Leupold website says:
When Leupold & Stevens, Inc.® purchased Redfield in April 2008, it did not acquire the capability to repair Redfield products manufactured prior to this purchase. The repair tooling and parts were purchased years ago by other repair services. Leupold & Stevens, Inc. will service its manufactured Redfield product (manufactured from 2010 forward) in accordance with its published warranty.
At this time, should a non-Leupold & Stevens, Inc. Redfield product require service, we suggest contacting Iron Sight, Inc. (918) 445-2001. This contact is provided for information purposes only, as Iron Sight Inc. is not affiliated with Leupold & Stevens Inc. They should be contacted directly for all information regarding repair, service and associated charges.
Redfield... | Answered on Feb 01, 2011
Dear Carl,
I have the same problem and have not been successful finding an actual manual. However, if you go to "abousainc.com" there is a link for general instructions. It is under "Redfield Scopes" and then scroll down to "How to use the AccuTrac." However, it does not give the starting point of the instructions and only gives the table for the different dials. I will try to explain what those 2 lines at the top of the reticle are for.
The average whitetail from the top of the shoulder to the bottom of the chest should fit exactly inbetween these 2 lines when the zoom is used correctly. If you notice, the yardage counter in the bottom left (4:00 position) it will tell the yardage of the deer when you zoom in or out and the torso fills these 2 lines. You may also notice it starts at 200yds. Thats because you need have your rifle zeroed in at 100 yds. So there's no point displaying less than 200 yds. This is where the different dials come in. For example: the deer is 300yds away. You zoom in or out until the torso of the deer is inbetween the 2 lines then look at the yardage in the 4:00 position. It should read approx 300yds. Then you dial up to the number 3 position on the elevation knob and aim as you would if the deer where at 100ds.
Look up which dial you need on the ABOUSA site on the AccuTrac tables I mentioned earlier. You might be lucky and find the dial you have is the right one for your caliber. If not, this company was once the offical repair facility for Redfield, Colorado. They also have the different dials for sale but are quite expensive...$10--$30 each.
Hope this helps,
Mark
Redfield... | Answered on Jan 25, 2011
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Redfield Optics | Answered on Oct 02, 2014
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Redfield Optics | Answered on Feb 13, 2013
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Redfield Optics | Answered on Nov 22, 2010
This may help you:
http://www.abousainc.com/ATsystem.htm
Nice sope!
DonB
Redfield Optics | Answered on May 01, 2010
Paul , got the fotos, now I know what you got. And now I know I don't have that one, but,,,, My local ace hardware has a ton of ancient bases and rings in a draw, I can go through them, also, did you try gunparts.com? They sell to the public and have just about everything known to man. E-mail,,, [email protected]
Redfield Optics | Answered on Feb 15, 2010
Redfield Revolution Riflescopes Logo
15 questions posted
Top Redfield Optics Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Redfield Optic Expert? Answer questions, earn points and help others
View Most Popular
Redfield Optics
  • Redfield Optics
Most Popular Question
redfield widefield
  • Optics
