20 Most Recent Kyocera Mita FS 1000+N Laser Printer Questions & Answers
The cd only has the drivers that were available when the printer shipped. You download the latest one here:
https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1100._.EN.html#WIN7
And yes, it does have drivers for both 32 and 64 bit Windows 7
Kyocera Mita FS... | Answered on Apr 01, 2017
Can you be more precise over what you are trying to disassemble.
Kyocera Mita FS... | Answered on Mar 09, 2014
It's not a settings problem, it's a problem with aging components inside the printer.
This is an issue with bump pads on the three solenoids/clutch electro magnets like these:
Arrow points to a pad.
They are made of sort of a spongy rubber, which decomposes over time and becomes soft and sticky. Being soft they get compressed, causing the metal levers coming into contact with the solenoid core and as a consequence being released too slowly.
The solenoids are located on the right (button & lamp) side of the printer. After removing the plastic cover, looking at the side, on the left there is a control board, which needs to be unscrewed, connectors detached (you won't reconnect them wrong, each is different) and the board removed. Under it you will see two of them and a third one almost hidden behind a moulded plastic cover, which also needs to be removed.
Unscrew two screws holding the first solenoid, scrub away (using a knife) the pad and any residual adhesive, and then find some cardboard that is ~0.5mm thick (needs to be dense, not easily compressed), cut out suitable rectangles, and glue one down in place of the pad using contact adhesive for example.
Screw the solenoid back in, reconnect it and unscrew the next one, doing the same repair.
Repeat.
Note: one of the solenoids has a two-sided lever, and has two bump pads; they both need to be replaced.
Keep the thickness close to 0.5mm; if too thin, you'll get a large margin again; if too thick, printing will start at paper edge or even beyond.
This worked for me beautifully, and is based on a writeup by user
BennyFu
I used pieces of cardboard 0.55mm thick (according to my caliper...), and pressed them down firmly to get good adhesion and some initial compression to get closer to the 0.5mm optimum.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Kyocera Mita FS... | Answered on Feb 22, 2014
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Kyocera Mita FS... | Answered on Feb 21, 2014
Your heater roller is not working
Kyocera Mita FS... | Answered on Jan 28, 2014
Download the PCL5 driver.
Kyocera Mita FS... | Answered on Dec 11, 2013
check this: http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Kyocera Mita FS... | Answered on Sep 27, 2012
This is a known problem.
Kyocera pretends to produce very silent printers. Therefore certain sheet metal parts inside the printer have a small piece of sponge rubber at their endings.
Unfortunately over the years this sponge rubber gets sticky. The corresponding lever, that is covered at its end with sponge rubber, sticks too long to its initial position. This is the reason why a certain lever is moved too late by the electromagnet into the position where a certain pulley is released.
As a result printing and paper movement are no longer coordinated and the printout is too low on the sheet.
Solution: Get rid of the sponge rubber, clean the lever very well in order to avoid it from sticking in its initial position. As a result you will here a much harder metallic noise when the lever moves, but the printout should be o.k.
Kyocera Mita FS... | Answered on Jan 27, 2012
Here just click the link below and you will be directed to the site where you can download the driver for your printer.
LINK
Be sure to choose the right operating system that you are using.
Goodluck. Hope i help. Please give me feedback regarding my solution thanks.
Kyocera Mita FS... | Answered on Jul 05, 2011
sounds like it got hit by lightning and needs some serious repair... consult a service technician... in your area
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Kyocera Mita FS... | Answered on Dec 24, 2009
ok thats nice
if paper is stuck in the back... then you have to take the machine apart... its messy but its just how it is... as for two sided printing... I would call kyocera support... they could best advize you on that... and they are quite friendly...
clean the paper feed roller with a damp cloth after removing the paper tray, otherwise call a technician since parts may need to be replaced, including the roller in case.
remove the process unit clean the charging wire ( in the pu unit right one green color lock is there move the lock right to left 10 times ) and check it ... if its not working please replace the charging unit and check .... if any issue please post your comments
Kyocera Mita FS... | Answered on Dec 16, 2009
Kyocera won't give it to you. You will have have an authorized Kyocera technician load it.
Kyocera Mita FS... | Answered on Jun 11, 2009
Uninstall the PRINTER'S DRIVER SOFTWARE completely from your system, MAKE SURE YOU USE THE PRINTER'S DRIVER DISK FOR IT OR ANY UNINSTALLER SOFTWARE FOR IT DONT UNINSTALL IT FROM CONTROL PANEL.... DISCONNECT PRINTER, TURN IT OFF. Clear All Temp And Prefetch Files. Restart Your System, Turn On Printer, Hook It Up To Your System,,, Go To The Manufacturer's Website And Install The Latest Driver Software And Firmware If Available....
Kyocera Mita FS... | Answered on May 21, 2009
l e d are villings countineve one by one up to down
Kyocera Mita FS... | Answered on Apr 09, 2009
Kyocera Mita FS 1000+N Laser Printer Logo
Popular Tags
29 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
kyocera mita fs 1000 paper slip single
  • Office Equipment & Supplies
