20 Most Recent Cabela's Pine Ridge Tactical 17 Riflescopes Questions & Answers
2answers
I recently purchased a Pine
There isn't much "specific" information I could find on adjusting this scope, but a web blog as some helpful information and reviews that will possibly answer your questions. First of all, notice that the blog states that the scope is good, at best, out to 300 yards, and they report blurriness at most anything over that distance. Here's the blog:
http://www.cabelas.com/fryprod-0/product--Cabelas-Pine-Ridge174-Tactical-17-Riflescopes--720492.uts.shtml
Not good reviews, really, but one fellow seems to have gotten it adjusted for the groundhog at 221 yards, so at least maybe the scope is accurate to that distance.
In the following blog, the last review states that Cabela will take the scope back if you're not 100% satisfied with it, so I guess they will.
At any rate, a lot of people had a lot of problems with this scope, and the reviewers suggested better ones, although a few more bucks.
Maybe it will work for you, but one person complained that the scope wouldn't keep it's adjustment, so it might be a continual battle.
Good luck, and hope this helps.
7/6/2013 12:52:07 AM • Cabela's Pine... • Answered on Jul 06, 2013
FACEBOOK
Ask your local vet.
8/3/2014 1:44:14 PM • Cabela's Optics • Answered on Aug 03, 2014
Need owners manual
for what?
4/19/2014 8:42:47 PM • Cabela's Optics • Answered on Apr 19, 2014
2answers
How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
5/23/2013 11:44:29 PM • Cabela's Optics • Answered on May 23, 2013
What the diriest river in the word
It's 1 of 3 and neither can be proven to be the dirtiest without studies
  1. Gangga in India
  2. Sarno in Italy
  3. Citarum in Indonesia
12/2/2010 7:36:16 AM • Cabela's Optics • Answered on Dec 02, 2010
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
5/31/2010 9:02:37 PM • Cabela's Optics • Answered on May 31, 2010
I need to order replacement
Hi Mark.
We need to know the binocular manufacturer to find the part. The n.70604012 does not return any known model.
Please tell us name of the manufacturer.
Thanks.
5/25/2010 7:32:40 PM • Cabela's Optics • Answered on May 25, 2010
3answers
How do I change Language on a sokkia set 250x total station
hi deshwashin error vod d13 brandt thnks
4/4/2024 7:00:30 AM • Optics • Answered on Apr 04, 2024
Need manual for edu science star tracker telescope
Yes I do
1/13/2024 1:28:24 PM • Optics • Answered on Jan 13, 2024
Tascos riflescope 3x9x50 adjutment caps
Visit your local gun shop and have them order them.
10/17/2023 10:13:50 PM • Optics • Answered on Oct 17, 2023
I need firing order for a 1981 Johnson seahorse 115
its just 1-2-3-4- with the port bank being 2-4 starting at the top and the starboard side being 1-3. They're all the same be it V-4 or V-6. 6=123456 60* and 90* are the same
5/31/2023 9:13:49 PM • Optics • Answered on May 31, 2023
Prime bluetooth wireless keyboard is not working
If the batteries are worn out or have not be put in properly. You may have to resync your devices the the USB receiver.
5/1/2023 6:31:18 AM • Optics • Answered on May 01, 2023
Franklin Chef FCE-42R Espresso Machine. How do I get a owner's manual for it please?
Question edited for clarity. Duplicate Question deleted. It doesn't seem to be available https://www.google.com/search?q=Franklin+Chef+FCE-42R+manual ..
3/13/2023 6:44:38 PM • Optics • Answered on Mar 13, 2023
Cross hairs do not adjust. Tell me what to do please?
All question need FULL 'make model (what it is)'. You posted to optics, so let's guess is a telescopic rifle sight? It is impossible to see and movement as the crosshairs move such a tiny amount. Half a millimetre in the sight is 10 feet at the target. The only way to zero in sights is on a fixed bench rest at the range. If you really think they are faulty, return them to the maker for repair.
3/8/2023 1:07:51 AM • Optics • Answered on Mar 08, 2023
Cabela's Pine Ridge Tactical 17 Riflescopes Logo
2 questions posted
Top Cabela's Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Cabela's Optic Expert? Answer questions, earn points and help others
View Most Popular
Cabela's Optics
  • Cabela's Optics
Most Popular Question
recently purchased pine
  • Optics
