20 Most Recent Logitech S120 2 Speakers Questions & Answers
0answers
Dont know how to install
got two pin plug on speekers no good in my house
10/31/2013 1:08:41 PM • Logitech S120 2... • Answered on Oct 31, 2013
How to disassemble logitech s-120 speakers
I bought the same unit with the same purpose. Unfortunately, the unit is totally glued together. There are no hidden screws. I found the solution on a Turkish forum (user xererx on http://forum.donanimhaber.com/m_42808409/tm.htm) You have to pry the front and the back pieces from one another. Take a thin screwdriver and carefully insert it to the front edge of the oval piece on which the volume control is mounted. It takes some amount of patience to break the seal first time. Then move the screwdriver slowly along the junction so that it breaks piece by piece. (It would perhaps help to heat the junction but I did not try it.) The slower you go through this process the cleaner will the separation be. Once you are done with your modification, you will need to glue the two parts back together again. Good luck. MCY. WebRepOverall ratingThis site has no rating(not enough votes)
5/7/2013 5:40:44 PM • Logitech S120 2... • Answered on May 07, 2013
0answers
No sound
Be the first to answer 3/9/2012 10:50:53 PM • Logitech S120 2... • Posted on Mar 09, 2012Be the first to answer
2answers
Not loud enough at max volume
The computer sound card has to have enough umph to drive the speakers. Most Netbooks and some laptops just don't have enough power to create loud sound.
9/24/2011 10:15:55 PM • Logitech S120 2... • Answered on Sep 24, 2011
Plugged in a few weeks ago and working great
try going to control pannel, add new hardware, and see if that works
9/17/2011 11:14:53 PM • Logitech S120 2... • Answered on Sep 17, 2011
My speakers wont work
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer if you need more help with this post a reply hope this helps
8/17/2011 7:21:34 PM • Logitech S120 2... • Answered on Aug 17, 2011
No sound mute works laptop speakers
what no sound mute(works on laptop speakakers) ?
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it hope this helps
7/6/2011 8:41:26 PM • Logitech S120 2... • Answered on Jul 06, 2011
They will not come on
If you are having problems with you sound: if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers: click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the: (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
7/4/2011 10:22:54 PM • Logitech S120 2... • Answered on Jul 04, 2011
My logitech speakers are not working each time i
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
6/29/2011 12:24:29 AM • Logitech S120 2... • Answered on Jun 29, 2011
We have some speakers that we pluged up and it
6/4/2011 8:37:31 PM • Logitech S120 2... • Answered on Jun 04, 2011
Logitech S120 2 Speakers Logo
33 questions posted
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
disassemble logitech s 120 speakers
  • Audio Players & Recorders
