20 Most Recent Eaton Powerware 9135 UPS (700465446) UPS System Questions & Answers
That error message is a DC over voltage error. You are going to be troubleshooting to the component level unless you can replace the charging board.
Eaton Powerware... | Answered on Dec 06, 2018
This is a correct statement. Swap your neutral and hot wires.
Eaton Powerware... | Answered on Mar 02, 2015
Pull it out and reseat it. If that don't work then you will have to replace the module
Disconnect your batteries first. Then turn off
If you locate a manual for this unit it shows it at the end of the installation manual with all the specs.
Eaton Powerware... | Answered on Sep 12, 2012
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: [email protected]
www.eaton.com/9135
Eaton Powerware... | Answered on Jan 06, 2011
the manual covers this, it tells you to read alarm event code
messages they are not in number format but text.
in clear english the alarms.
RTM or call EATON, we are Fixya not EATON,ok>
most error common means bad batteries. 99% are.
http://www.eaton.com/content/dam/eaton/products/backup-power-ups-surge-it-power-distribution/backup-power-ups/eaton-9130-ups/eaton-9130-ups-pdm-user-guide-manual-164201798.pdf
Eaton Computers... | Answered on Dec 08, 2019
Hello Eugene
This is the only post that you have posted here on Fixya dot com, albeit you have posted this same thing twice. Therefore I suspect you asked the question elsewhere and then came here to complain about it!
I suggest you contact Eaton direct by phone.
https://www.fixya.com/users/eugene-loach
Andrew - Fixya Moderator
see the instruction booklet for that - - - or contact eaton directly.
UPS used lead acid batteries which die after 3 or 4 years. Disconnect the power and open it to see which ones it uses. You will know they are dead if they have swollen or melted. Buy replacement batteries.
learn that when you have black out.
the batteries TAKE OVER< and are huge stress on any battery like this,, and when the lights (AC power) turned the UPS tries to charge said batteries and are now bad.
time for new batteries, or let it beep for 24hours and hope the batteries can recover.
the manual tells you how to see if the batteries are bad and with errorcodes, on all UPS made. RTM read the manual first.
no 2 UPS are the same , unless are.
the first is battery voltage under charge, if too low that means
a cell in 1 battery is shorted. as the LOVE TO DO.
no UPS stated, model.
how old are you batterie(s)
charging errors of most kinds means the battery is bad.
they can do that even year old, but mine last about 3 years on avg.
no battery in any USB with Gel Cells, last a long time.
a fraction of all else inside the box. in fact.
buy a new battery and put it in.
Eaton Powerware 9135 UPS (700465446) UPS System Logo
Popular Tags
14 questions posted
Top Eaton Computers & Internet Experts
Gruber Power...
Gruber Power...
jimixclay
Tom Chichester
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Eaton Computers & Internet
Most Popular Question
charger fault service required alarm
  • Computers & Internet
