20 Most Recent Lanier 5222/27 Laser Printer Questions & Answers
2answers
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
8/12/2014 9:23:43 PM • Lanier 5222/27... • Answered on Aug 12, 2014
Problem on RADF misfeed but no misfeed at all. what should I do
please clean the sensors located in the RADF and power the machine and the problem is over
6/13/2014 9:39:14 AM • Lanier 5222/27... • Answered on Jun 13, 2014
Lanier 5635 error code displaying
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
11/18/2010 1:19:01 AM • Lanier 5222/27... • Answered on Nov 18, 2010
My lanier is making dark
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
11/18/2010 1:16:38 AM • Lanier 5222/27... • Answered on Nov 18, 2010
Blank streaks
Hi
You need to replace drum
or try cleanning it with a soft paper towel
Pls vote us to keep us alive
11/16/2010 10:30:46 PM • Lanier 5222/27... • Answered on Nov 16, 2010
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
5/21/2010 4:10:59 AM • Lanier 5222/27... • Answered on May 21, 2010
We are getting the error
This error code sc391 indicates an electrical problem within the photo conductor unit. The development bias may not correct. Turn the machine off, wait 10 secs and turn on again. If it was a sensor problem it will reset it. If this does not work remove the Photo conductor unit (PCU) and reinstall it. (bad connection may be fixed by this way)
If that does not work, this may be a problem with the high voltage supply to the board, in which case a service call will be needed to rectify the hardware issues.
I hope this is helpful for you.
Thanks
3/4/2010 5:46:30 PM • Lanier 5222/27... • Answered on Mar 04, 2010
I have a Lanier 2138
Hi.
SC555 means that the pressure roller thermistor is returning values that are not in range.
When that happens, either the thermistor is defective, or the wiring is broken.
Try disconnecting the power cord, to reset the printer and to allow the fuser and thermistor cooling down. Wait one hour, then connect back.
If that does not fix the error, or if the error comes back , then the fuser unit must be replaced, or serviced by a technician replacing the thermistor.
Regards.
2/10/2010 2:32:29 AM • Lanier 5222/27... • Answered on Feb 10, 2010
Lanier 5527 that is displaying SC541
This is a fuser error, you will need a service call.
2/10/2010 2:25:51 AM • Lanier 5222/27... • Answered on Feb 10, 2010
I need a nic for a lanier 5222
WE can get you a Nic card but they are not free. ([email protected])
--Carl, let me know if this helps.
6/27/2009 4:13:55 PM • Lanier 5222/27... • Answered on Jun 27, 2009
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
6/22/2009 12:24:34 PM • Lanier 5222/27... • Answered on Jun 22, 2009
Misfed jams
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
2/24/2008 4:38:03 PM • Lanier 5222/27... • Answered on Feb 24, 2008
Popular Tags
31 questions posted
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Marvin
Marvin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
lanier making dark
  • Office Equipment & Supplies
