20 Most Recent
Edimax EW7416APn (EW7416APN) Pre80211n Wireless Access Point Questions & Answers
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices. Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.Good luck!
How can i re configure my computer on windows xp to see my edimax 7416apn now i have a new router
In the "system tray" (the area down near the clock in the lower right-hand corner), you should see an icon that either has bars like on your cell phone, or some kind of icon with waves coming out of it (not the speaker icon). If you don't see an icon like that, then wireless networking is not on. If you do see that icon, click on it, and a list of available networks will pop up. You need to pick the one for your access point. If you didn't change the SSID (network name), then "Edimax AP" should appear on that list. Click on it.
Cannot access 192 168 2 1
The DHCP of the router has not been set-up, you need to follow these instructions to access the router by making changes to your computer. You also need to connect to the Ethernet port direct with a cable to program the router.
How to login to AP page
Psp connection lost
You cannot, your device cannot support the security protocol used by the EDIMAX access point.
