20 Most Recent Liebherr SBSes 74S2 Premium NoFrost Questions & Answers
2answers
Liebherr Premium NoFrost (freezer below, fridge
I can not find parts for my liebherr refrigerator
8/18/2018 11:36:36 AM • Liebherr SBSes... • Answered on Aug 18, 2018
On Saturday, I tried to
We need to know the model and the manufacturer of the refrigerator.
6/25/2017 11:37:35 PM • Liebherr SBSes... • Answered on Jun 25, 2017
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
6/30/2015 11:25:29 PM • Liebherr SBSes... • Answered on Jun 30, 2015
0answers
My fridge keeps frosting up and everything is
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/10/2011 8:03:39 PM • Liebherr SBSes... • Answered on Aug 10, 2011
I have a Liebherr No-Frost
For that problem, the electronics control board and the thermostat must be check. Since the display doesn't follow the control button and it adjust itself automatically without controlling, it's already sure that the control is the problem. Check first thermostat then electronics control board. Be sure that the door are tightly close.
It is a pleasure to advice you.
7/9/2011 11:22:18 AM • Liebherr SBSes... • Answered on Jul 09, 2011
Liebherr cnesf 5013 superfrost always beeping
Maybe it is only in the settings, I don't know the details of your ref but I would like to suggest to consult it in the technical experts.... because you said, it is turning on and off but it is working, maybe you only mistakenly click some button but if not, the refrigerator is the problem ( if it is new one, you can return it and replace a new refrigerator but in this case, you need to check it before replacing another one)
10/29/2021 4:02:51 PM • Liebherr... • Answered on Oct 29, 2021
My Liebherr premium freezer keeps dropping temperature.
call a local repair service
6/16/2021 12:29:20 AM • Liebherr... • Answered on Jun 16, 2021
My integrated Liebherr brand new fridge/freezer is making a clicking sound? Fan? It’s not the alarm
then you have the dealer send out the tech to fix it we do not try to fix NEW things warranty work
5/29/2021 8:48:19 AM • Liebherr... • Answered on May 29, 2021
I have a Liebherr fridge CS 2062. Both doors gaskets need to be replaced. What are the part#s and where to order? Thanks
That's not the way it works. Normally you contact a company and say "I want door gaskets for a Liebherr CS 2062". Let them worry about part numbers. They are here https://www.letstalkparts.com/Liebherr-Appliance-Parts-s/283.htm https://www.google.com/search?q=Liebherr+fridge+CS+2062.+doors+gaskets ..
4/7/2021 9:01:40 PM • Liebherr... • Answered on Apr 07, 2021
Liebherr fridge stops working after 1 hour.
The Spaminator Mar 22, 2021 Hi Jasmin Black, I suspect ice build up behind the back panel of the freezer could be causing this. this could be due to a faulty thermostat transducer that tells the freezer to defrost when the ice builds up.
3/22/2021 10:25:01 AM • Liebherr... • Answered on Mar 22, 2021
Model CN4003-21. Why doesn't the refrigerator part cool?
first check the freezer compartment temperature
12/4/2020 7:32:47 PM • Liebherr... • Answered on Dec 04, 2020
Liebherr C1650 Refrigerator Ice Cube Maker Problem: making cubes but also spilling excess water.
Descale it. Clean it with a brush. check the inlet is clean. Check the drain is clear. However, it is a known issue. Advice here https://www.houzz.com/discussions/2333121/liebherr-36-icemaker-problems Page 20 http://assi.lhg.liebherr.com/Serviceline/b2b/bab2b/Media/Documents/BA/708248101_gb.pdf ..
11/29/2020 7:46:00 PM • Liebherr... • Answered on Nov 29, 2020
Why Liebherr CS 1651 freezer temperature keep flashing
snelvrieser aan of temp onder 16 gr
8/19/2020 6:21:07 PM • Liebherr... • Answered on Aug 19, 2020
Liebherr SBSes 74S2 Premium NoFrost Logo
21 questions posted
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
liebherr premium nofrost freezer below
  • Refrigerators
