20 Most Recent ASUS P7P55DE Pro Motherboard Questions & Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
ASUS P7P55DE Pro... • Answered on May 27, 2011
SixEngine needed permission too though not TurboV. So, though I found out how to run it as admin, it's useless so I just uninstalled it.
1) http://www.sevenforums.com/tutorials/11949-elevated-program-shortcut-without-uac-prompt-create.html
2) http://www.sevenforums.com/tutorials/11841-run-administrator.html
I wouldn't want turboV to run without prompt: so anyone could adjust system voltages. If this is what turboV does, no way, and mine sadly doesn't need permission to run. Fortunately, I am the only user.
ASUS P7P55DE Pro... • Answered on Dec 20, 2010
Needs to have an operating system installed on the hard drive.
ASUS P7P55DE Pro... • Answered on Sep 16, 2010
Try control panel, display,screen saver,power adjust settings from there always apply changes/settings before closing
good luck
ASUS P7P55DE Pro... • Answered on Aug 29, 2010
https://www.manualslib.com/products/Asus-X555la-5887002.html
ASUS Computers &... • Answered on Jul 12, 2021
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Did you try manuals.com?
ASUS Computers &... • Answered on Jun 19, 2021
find out what the vga card is then go to the manufactures website e.g. ATI/nvidia/intell
First you need to download this driverupdate us software (for free) and scan your PC. after scanning, driver will be found and you will be able to update in couple of seconds. best of luck
n13219 is actually the asus P8H61 motherboard
If You Are Looking For A Manual For An ASUS Mainboard Model No: N13219 I Give You This Advise: Try To Find And Download It From The Internet Using Google !
Try to use some soft to get info about your PC for example: Everest, SiSoft Sandra, HWiNFO... Hope some of this apps wil recognize your graphics adapter.
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
ASUS Computers &... • Answered on Mar 29, 2021
Schematics are not released or available as they are in house replacement items.
ASUS Computers &... • Answered on Mar 11, 2021
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low. Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.The first number is width, so say it's on 800x600 then go 1024x768
ASUS Computers &... • Answered on Feb 23, 2021
You can use PLEX install on PC and Google TV or try AVIA or Media House through google play
ASUS Computers &... • Answered on Feb 18, 2021
ASUS P7P55DE Pro Motherboard Logo
7 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
usb problems not read thumb drive
  • Computers & Internet
