20 Most Recent
Iomega Rev 70GB Disk for Use with Rev 70G Drives (33506) Drive Questions & Answers
I'm running OS 10.13.6 on a mac book pro. My Iomega MDHD500-TE is not recognized. What to do?
I suspect that you don't have an Iomega driver in play for use with this Macbook pro that the OS recognizes. There are other possible explanations, you might have a corrupted volume or there might be a problem with the file structure on the Iomega. But if the Iomega was not previously recognized by this MacPro, I think what is missing is a useful driver. You might try one of the driver hunter utilities and see if it finds such for the iomega. If several are found, you would have to try each one at a time and uninstall any that did not work before trying the next, I think.
Here is something else you might try. On the MacPro, on the desktop go into Applications>Utility folder and from the Utilities folder launch the Disk Utility application. If your Iomega is discoverable, it will show up in the left side of the Utility window. If you see it, click on the left side of the window and choose Disk Repair.
If you don't see it in the left side of the Utility window, you may have a corrupted volume preventing it from properly being read on your Mac or there may be a problem with the file structure of the Iomega.
I loaded a number of files awhile ago on my ex
Try going to contol panel then administrative tools. In the window that opens look at the left window pane for disk management click on it. You should see the disk that says you need to format it, Compare file systems your c drive and the disk you can't read. (Fat32, NTFS, Fat) Right click on the disk that's giving you problems and see if Vista will let you mount the drive. If it won't you should put the drive in a portable enclosure and use a Windows 7 PC to Burn your files to disc. Vista is extremely unstable If you can load Windows 7 your problem will go away and you'll have a way better OS!
I have an 2005 iomega
Whatcha got a do is check yer properties, if it's full you'll have to reformat the disk to FAT32 then git the files an zip em up an transfer em over that way an you should be all good..
