20 Most Recent CTL 2goPC Tablet Questions & Answers
i need 2go account
CTL 2goPC Tablet | Answered on Mar 11, 2014
Dear Bob,
When this happens, in general it is because the computer's real time clock battery (also known as RTC battery, CMOS battery or BIOS battery) is depleted. It is not the power battery at the back of your device - generally it is located inside the PC and looks like a small coin with the size of a dime or a quarter. If you search in image.google.com for CR2032 or CR2016 you will see different brands and assemblies for them.
It is the power of this battery that is used to maintain the real time clock circuit working when you switch off or remove the power or the main battery from your PC, keeping the date and time being updated continuously.
To change it, you will need to unscrew and remove the back covers of your device and look for this kind of battery. Buy another one with the same size and thickness (check their model, like the ones mentioned above) and reinsert it to the same holder where you took it from. If it is soldered to a cable and connector, you will need to find one assembled like that or you will have to ask a repair technician to do unsolder the cable from the oldest one and solder it to the new one for you (always remembering to isolate it with electrical tape before connecting it to the circuit, to avoid short circuits).
In the next time you power your device on, it may warn you that the CMOS battery was changed and you will have to enter the BIOS setup and adjust it accordingly. The next time you switch it off and on again, it is supposed to work properly, without resetting the date and time.
Hope you may find this helpful!
Best regards,
Miguel Luiz Martins
CTL 2goPC Tablet | Answered on Nov 20, 2013
Sounds like a CMOS battery problem, assuming the internal power battery is working fine. May have to get someone to open your tablet PC to replace the battery (cmos)
Want to sign up
CTL 2goPC Tablet | Answered on Apr 17, 2012
I want to register
CTL 2goPC Tablet | Answered on Sep 19, 2011
My onn 8 inch tablet won't come on????
Tablets &... | Answered on Oct 12, 2020
To delete vpn from you ipad you can simple go to Settings > General > VPN. Here you will see all the vpn connections created on your device. Here you can delete it. You can review detailed instructions here: Sahrzad VPN How to Setup Guides
Tablets &... | Answered on Oct 08, 2020
You can try searching on google for the Audiosonic T17b 7" tablet manuals
Tablets &... | Answered on Oct 06, 2020
the are services that can unlock the tablet serch ebay
for google lock or google unlock service for your model
the do it by teamviewer(they get connected to your computer to do it
Tablets &... | Answered on Sep 30, 2020
There is a good chance this will Not be repairable unless your prepared to spend a lot of money. It may be cheaper to simply replace the whole unit.
Tablets &... | Answered on Sep 25, 2020
Try going into TV settings and reset to factory state.
Tablets &... | Answered on Sep 23, 2020
A blue screen with this error code means you can't boot the system normally, this could be as a result of corrupt or missing system files, hardware issues, damaged boot sectors or faulty apps/programs including games from unknown sources.
Tablets &... | Answered on Sep 17, 2020
CTL 2goPC Tablet Logo
22 questions posted
Top CTL Tablets & eReaders Experts
Marvin
Marvin
Are you a CTL Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • CTL Tablets & eReaders
Most Popular Question
2go registration process
  • Tablets & eReaders
