20 Most Recent Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook Questions & Answers
hello mr, Matt the hyjacker?
why not ask using all your facts, and not OPs
my wild guess is the OP inserted to the docking station
and bent pins, and now will not work.
the word unlock here is poor choice of words
as many docking stations have option key mech. KEY lock.
so if NOT a key lock !
then it is just mechanically jammed
why not get someone to fix it
or try to unjam it your self , I am sure the OP did 8 long years ago.
or sold it or scrapped it.
invert the whole thing, LT and dock.
upside down, now press dock firmly the LT bottom
near the Connector end and at same time...
then unlatch the dock using the dock latch release now.
this relieves pressure (gravity) and can aid in the cure.
Lenovo ThinkPad... | Answered on Aug 17, 2018
Hi Sandeep,
The screen displays is dim because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
Hope this answers your question!
Good Luck!
Don't forget to convey your feedback
CreativeTECH
Lenovo ThinkPad... | Answered on Jan 17, 2011
CONFIGURE BLUETOOTH WITH COMPUTER
Hi friends
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Lenovo ThinkPad... | Answered on Jan 11, 2011
go to the start control panael ->add remove programs->uninstall you can uninstall your antivirus
Lenovo ThinkPad... | Answered on Jan 04, 2011
Yes you can download Whatsapp on your Laptop by follow simple steps.it is very easy to download it on your PC by using some emulator WhatsApp FOR PC WINDOWS AND MAC .Download Whatsapp from this link..
Also download fresh Android App on your PC Such as Asphalt 9 from this link.. Asphalt 9 FOR PC WINDOWS AND MAC
Lenovo ThinkPad... | Answered 3 days ago
Error code 36 means a ley is stuck. Only you can find out which one. Press each key in turn to feel if there is a dodgy key.
Lenovo ThinkPad... | Answered on Oct 09, 2019
remove the battery large.
then run on AC pack only
#1 top failure of all mobile PC is that battery, so unplug it
then test with AC pack only.
work now.? and all vents must be clean, end to end. not just fan.
there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
OK big battery out, an RTC coin cell fresh.
then fan blows.
next is BIOS, do the BIOS screens work if not the mobo is dead.
have 2 RAM stick on the 2 slots>? try one at a time
run the PC with all modules removed, (options)
remove hdd?
remove, dvd drive.
think like this. Get bios working first
learn that modules can short, and when they do the power regs shut down.
so we unplug all things to the mob,
until only 1 ram and cpu remains.
see? (this is called power overload fault isolation tactics)
even the screen only can be dead, you never mention text showing
you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
Lenovo ThinkPad... | Answered on Aug 14, 2018
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
1. Unlock your Android device
2. Find the Applications menu and select "Settings"
3. Under the "PERSONAL" group, select " Security"
4. Under "SCREEN SECURITY" group, select "Screen Lock"
This will ask for the security pattern first.
5. The options for screen lock will appear, select "Slide" and you are done!
Hope this helps.
Lenovo ThinkPad... | Answered on Mar 14, 2017
Press Ctrl and PrntScr together. That will grab the screen then open your document programme, (Open Office, Word or whatever you use to compile letters etc) press Ctrl and V.
Lenovo ThinkPad... | Answered on May 23, 2016
It is printed on your invoice/receipt after purchasing it.
Lenovo ThinkPad... | Answered on Jan 16, 2016
Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook Logo
7 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
unlock 4338 docking station laptop will
  • Computers & Internet
