20 Most Recent Dell Vostro 1014 Laptop Computer Questions & Answers
Those are not simple problems. From your description, you probably gonna need to replace both the screen/flat cable and the keyboard (these parts just can't be repaired, must be replaced).
Dell Vostro 1014... | Answered on Dec 19, 2017
format HDD nad make active partition
Dell Vostro 1014... | Answered on May 25, 2016
I also had the same problems in my laptop, but I had tried many ways, this problems couldn't be fixed. A friend told me maybe I need to reintalled the system. However, I didn't want to do. Finally, I tried to use other wifi software. A program named OSToto Hotspot can run. You can have a try!
http://www.drivethelife.com/free-wifi-hotspot-creator.html
Dell Vostro 1014... | Answered on Nov 17, 2015
Here is a tutorial for you to create WiFi hotspot on Dell computer. A prgram named OSToto Hotspot can help you!
http://www.drivethelife.com/wifi/how-to-create-free-wifi-hotspot-on-windows-10-8-7-xp-vista.html
Dell Vostro 1014... | Answered on Oct 30, 2015
Based on information provided, it seems that the issue might be with bluetooth driver or even with the driver for the function keys(Fn)
The best option would be to re-install the bluetooth and the function key drivers.
Please let me know if you need detailed information about the driver installation procedure.
Hope this helps..
Dell Vostro 1014... | Answered on Feb 19, 2015
Download "Connectifyme". It is a free version with other powerful options in paid version.
But keep in mind. You either need 2 wireless adapter, 1 for internet connectivity and 1 for hotspot.
Or, you connect to the internet via LAN port and wireless adapter for wireless hotspot.
Or, connect to the internet via LAN port to a wireless modem and hotspot with your builtin wireless adapter.
Let me know if you need more info.
Dell Vostro 1014... | Answered on Dec 07, 2014
Press Windows+R on the keyboard, type the following:
devmgmt.msc
and press enter. Chances are you will find a disabled wireless card under the Network devices section. Right click it and select Enable.
Dell Vostro 1014... | Answered on Sep 09, 2014
Hi to turn on the wifi you need to press the Fn + F11 keys together
Dell Vostro 1014... | Answered on Apr 15, 2014
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Dell Vostro 1014... | Answered on Mar 20, 2014
Reboot check taskManager you CPU is probably running at %100
you'll have to disable unnecessary start up items that are using up you're resources. Also you may need more memory.
to check start up run (msconfig) and click tab (startup) untick anything unnecessary.
Dell Vostro 1014... | Answered on Mar 14, 2014
2 days ago i was used windows7.
But then my pc was very slow.
so i thought that now i gate new setup
so i try to get setup win732bit but still now
i cant got set up.
when i try to set up i found error massege.
Then i try to format my local drive but i can\'t .
befor when i get setup then it dont gate more time like now.
Now it get more time but dont get setup.
Dell Vostro 1014... | Answered on Jan 10, 2014
If you wish to FORMAT your hard drive so you can re install the OS.
Put your Windows disc into the CD/DVD drive, boot the computer and press F2 (if that does not work try CTRL+ALT and enter) to enter the bios. Change the boot order to boot from the CD drive first.
Follow the onscreen instructions to Install the OS, you should get the option to delete the existing partitions and then to FORMAT.
Dell Vostro 1014 Laptop Computer Logo
155 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
hotspot software always displaying error
  • Computers & Internet
