20 Most Recent
Dell Inspiron 1750 Notebook Questions & Answers
2 beeps at startup
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
No main video. external video vga works
Seems to me that you may be experiencing a BIOS issue I would go to Dell web site and download the BIOS again for sure to make sure the BIOS is back to working order. This may be the issue try this and any other drivers that have to do with video you may have a corrupted driver along the line here that is how I would handle it.
Click Here
How to restore back to factory
have you tryed "system restore" on your computor it will restore it back to a date specifyed by you, or you can take it in will cost.
Hello sir.i want to just ask abourt my dell laptop
You should be able to Right-Click your desktop and go to the "Themes" or "Properties" section of the pop-up menu that shows up.
Then find the appropriate changes you want to make, select "Apply" and done!
My laptop continuosly freezes? what could be the
Three things could be it:
- failing disk drive
- failing memory
- virus
#1 Run manufactures diagnostic. Their web site will have the download
#2 Google MemTest86 and run
#3 Go to TrendMicro.com and scan for viruses.
Hello i need the master password to clear cmos for
I don't think there is such password.
You could contact dell and ask for the password if there is.
If not then best option is to remove and reseat the CMOS battery.
Contact Dell and tell them to provide you with the steps to remove and reseat the CMOS battery.
It will reset all the BIOS values.
Once i open my computer dell 1535 it request for
I have few questions before we proceed, is the question being asked before you reach the "logon screen"?. There are different passwords like bios password, hdd password, and user password. If you didn't set the user administrator password, just leave it blank and hit enter. Please let me know with the operating system running on your system.
Good luck.
Thanks for using FixYa.
Bios password
browill2000
If you need your BIOS password reset for your notebook you will need to call Dell tech support. They will give you a code for your notebook to reset the BIOS password.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
