20 Most Recent CTX Optoma EzPro 610 Multimedia Projector Questions & Answers
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
CTX Optoma EzPro... | Answered on Feb 17, 2011
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
CTX Optoma EzPro... | Answered on Apr 26, 2010
not all laptops are fn f8 find pic of monitor and fn key, if this doesnt work adjust display resulution same as desktop
CTX Optoma EzPro... | Answered on Apr 13, 2010
Hi I have a Optoma EZPro 610 that does not turn on. I know it's getting power because I can see the fan trying to move but it does not spin. I have no lights at all. I just got this from a friend and I don't know if the bulb is good. Is there a way to test the bulb? Any help on this would be much appreciated. Thanks!
CTX Optoma EzPro... | Answered on Dec 28, 2009
that is due to lcd filter problem
CTX Optoma EzPro... | Answered on May 21, 2009
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
CTX Optoma EzPro... | Answered on May 12, 2009
you only need to post once y'know ;)
CTX Office... | Answered on Jan 31, 2014
Can't help directly I'm afraid, as that thing is probably 10 years old now and the manuals aren't online anywhere.
Have you tried just being ghetto and putting different numbers of beer mats under each of its support feet until the picture's evened up? (The feet should themselves hopefully be adjustable by screwing them in/out OR by using a push-to-release catch that lets you pull them in/out)
Close the cover.
Office Equipment... | Answered on Feb 22, 2021
This appears to be a shredder rather than a Car and Trucks issue. I have moved you to the correct category and edited your question for clarity.
Remove the head and vacuum all the dust and paper bits, top and bottom. There is a sensor in there that is looking for a sheet of paper. When you turn it on, it thinks it has found it. While you are at it, oil the blades.
Staples SPL-TXC12M7A Paper Shredder Review
www.goodhousekeeping.com > appliances > staples-spl...
Jul. 6, 2012 - The Staples SPL-TXC12M7A offers most of the conveniences you'd expect from a 12-sheet shredder. This moderately priced model was ...
Staples SPL-TXC12M7A Shredder SPL-TXC12M7A for sale ...
www.ebay.com > ... > Office Equipment > Shredders
Find many great new & used options and get the best deals for Staples SPL-TXC12M7A Shredder SPL-TXC12M7A at the best online prices at eBay!
I didn't understand this??
What is that??
I tried all the above - nothing worked - eventually I stuck a letter opener into it and wiggled it about until I released a staple that was stuck at the back of the machine - then this released the staple carrier.
CTX Optoma EzPro 610 Multimedia Projector Logo
Popular Tags
11 questions posted
Top CTX Office Equipment & Supplies Experts
Marvin
Marvin
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • CTX Office Equipment & Supplies
Most Popular Question
verticle purple line right side screen
  • Office Equipment & Supplies
