20 Most Recent
Dell Inspiron Mini 10 Netbook Computer (Intel Atom Z520 160GB1GB) (dndofm61) Questions & Answers
Dell laptop says preparing to hidernate
When winter comes, bears go to hibernate. After you press the hibernate button (if it has one) your computer goes to hibernate. To revive it press or slide the power ON button.
Touchpad jumps inspiron mini
Click Start/Control Panel and adjust the mouse touchpad.I would set it to the default settings. If it still acts crazy download and reinstall the drivers.Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
How can I tell whether
I'm not sure but if you follow the following steps, may be, you find it. Hope this may be useful for you. Click over START. Select CONTROL PANEL. Then, select SYSTEM. Verify if you can find what are you looking for under Computer in the General tab. Good luck!
Keyboard on Inspiron Mini 10 is not working right.
The only way that I have cleaned those keyboards is taking each key out one by one and wiping them and the keyboard itself. But you must be extremely careful that when you put them back you don't brake the back part of the keys as they are very sensitive.. Or for about $35 dollars you could just purchase a new keyboard and install it yourself and avoid the headache. It is very easy to change, just make sure that you are very careful when removing it since it does have a wire that hooks up to the motherboard.. You must remove the battery and there are just 2 screws that hold the keyboard in place, remove them and pull the keyboard out gently. Here's a link where you could purchase the keyboard:
http://www.parts-people.com/index.php?action=item&id=8895
Let me know if this answers your question and good luck..
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops:
Inspect and clean the air vents and fans
Restart the computer
Update the BIOS and Chipset driver
Download and install Microsoft Windows updates
Run a hardware diagnostic test
Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops)
Improve efficiency to reduce heat
Perform a Windows System Restore
Restore the computer to factory defaults
