20 Most Recent Lenovo T410 Notebook Questions & Answers
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Lenovo T410... | Answered on Aug 01, 2015
That was the only way to fix this.
Lenovo T410... | Answered on Jul 11, 2012
check to make sure the mute is not on by clicking on the speaker icon in your task bar.Also make sure the volume is not turned all the way down.If that is not the problem check your device manager to see if the card is disabled.
Lenovo T410... | Answered on Aug 12, 2011
http://sourceforge.net/projects/pcloginnow/
DOWNLOAD PCLOGINNOW FROM THIS LINK
BURN THE ISO IN A CD
BOOT FROM CD
select an account and check 'is password empty' check box
IT WILL clear the PASSWORD for that account
YOU CAN ALSO TRY
USERNAME-ADMINISTRATOR
LEAVE PASSWORD FIELD BLANK
Lenovo T410... | Answered on Dec 29, 2010
That depends on the country and model of laptop.
Lenovo Computers... | Answered on May 10, 2020
need to try cleaning it if that dont work replace it they are inexpensive
Lenovo Computers... | Answered on Apr 24, 2020
1) Turn on your mic 2) Start windows sound recorder 3) Start recording 4) Jam out on your instrument(s) 5) Stop recording 6) ... 7) Profit
In truth, this is a terrible device to record music on. You should look into getting a mixer (with as many tracks as you need) and a dedicated computer with a high quality sound card (M-Audio) is a good brand.
If you're thinking about making electronic music, look into FL Studio. http://flstudio.image-line.com/
More details would allow me to answer with more precision.
Lenovo Computers... | Answered on Apr 09, 2020
then you need to go see a computer repair service for a new battery possibly .
Lenovo Computers... | Answered on Mar 24, 2020
how to remove sim slot permanently lock in lenovo s90-a
Lenovo Computers... | Answered on Mar 12, 2020
Not a quick fix, but if it is a socket connector, you can take it apart and replace the socket. Check your local electronics components store.
Lenovo Computers... | Answered on Feb 15, 2020
Take it to a repairman. seems the screen VGA input has an issue.
Lenovo Computers... | Answered on Jan 20, 2020
Hello Jason,
The error message that u have mentioned seems that the virtual memory(page file) is less. please increase it from
Start>>Control Panel>>All Control Panel Items>>System.
On the left hand please select the option"Advanced System Settings".
In the System Properties Page select Advanced.
Under Performance option click on Settings tab.
In Settings select Advanced tab.you will find the option Virtual Memory
click Change Uncheck "Automatically manage paging file".
Now, Select your drive and click custom size and enter the minimum and maximum size from the details available in bottom under total paging file size.
click OK and restart your PC.
Lenovo Computers... | Answered on Jan 17, 2020
Settings - Display - Uncheck Mirror Display.
Lenovo Computers... | Answered on Dec 24, 2019
ask them yet, the actual makers,
no 2 PCs on earth reset the same way (bios)
https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/flex-series/flex-3-1470
ask the maker, first.
Lenovo Computers... | Answered on Dec 17, 2019
First, I'm Not an Lenovo tech
* Contact Lenovo for support; https://www.lenovo.com/us/en/
*** Following is for information only.***
* Forum refers to a cable; https://forums.lenovo.com/t5/Android-Yoga-Series-Tablets/Yoga-tab-3-connecting-to-tv/td-p/2259037
* Cable; https://www.lenovo.com/us/en/accessories-and-monitors/cables-and-adapters/cables/CABLE-Lenovo-DisplayPort-Cable-Kit/p/0A36537?cid=us:cse:qza7ob&utm_source=CSE&utm_medium=Banner&utm_campaign=CSE__Connexity
* Customer review; https://www.youtube.com/watch?v=nYsz8_zdOAA
Aloha, ukeboy57
Lenovo Computers... | Answered on Dec 11, 2019
Thank you for contacting Fixya.
Based from what i read in your post, seems like some hardware issue, Please try disconnecting all cable and hard drive , optical drive & card reader.
Create a minimum set and check booting the system also tries using some different Memory module to verify. If system is working fine, now try connecting devices one by one to check which device is creating the issue.
If Issue is not fixed please contact local Lenovo Support to have your system verified
Lenovo Computers... | Answered on Nov 24, 2019
Lenovo T410 Notebook Logo
Popular Tags
9 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
sound not working
  • Computers & Internet
