20 Most Recent
Toshiba Qosmio X505Q880 (PQX33U01J00H) PC Notebook Questions & Answers
Video card Problem
If the card is sort of like a desktop video card then you by a a replacement. if the video card is integrated in the motherboard there are some companies that promise to replace it. Not an east task and price range is 90 to 15o US dollars.
If you can see video on an external monitor then the GPU is ok.
Black screen after updateing the bios
If you did a backup before you upgraded the graphics driver then I would restore this. I would then do upgrades one step at a time with a full backup between upgrades.
If you don't have a backup then I would take the opportunity to rebuild the system and take backups at various stages.
By doing the backups regularly you wont get caught out by so called upgrades which actually do the opposite.
I have a x505-q880 qosmio laptop it has a poweron
If you have a Windows password reset disk, you can easily reset
forgotten Windows password with it. If not, you can follow the steps to create one. You just need an available computer
which can link to the Internet.
Step 1: Download and install
Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset bootable CD/DVD or USB flash drive.
Step 3: Reset your forgotten Windows password with the created disk or USB.
It is easy and safe.
I just got my Qosimo laptop and a window saying
The cooling fan is worn out and it vibrates. That vibration is lethal to the hard disk so its protection system has temporarily put it in a safe state. The only way to fix that is to replace the fan and this is a job for a repair shop.
When laptop says no bootable device
It means that you do not have a hard drive that can be booted to start the OS, or that your had drive is defective, or the boot sector of the hard drive is missing or corrupted.
Wireless capability turned on
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
Beep codes
Did you solve the problem? I have the same here, in Brazil.
I have a rj111 cord jsrAA.where do i plug back in
On the right hand side after the USB sockets there is a drop down flap. Underneath are the RJ11 modem and RJ45 network sockets.http://www.notebookcheck.net/fileadmin/_processed_/csm_Anschl._rechts_01_129c1d9a1d.jpg
I had friends over and they were logging into
Reboot your computer, OPEN YOUR CHROME WEB BROWSER, AT THE TOP RIGHT HAND CORNER CLICK THE THREE BARS, SCROLL DOWN TO SIGNED IN AS CLICK ON IT, SCROLL DOWN TO USER, SIGN IN AS ''NEW USER'', CLOSE BROWSER..OPEN FACEBOOK AND LOGIN...
My Toshiba F45AV410 won't boot after turning it
It's a vague description...A/If you see a blank screen and you can hear some noises... it will be the screen (LCD) , Plug it into a computer Monitor and see if you get a picture off it. B/If you get nothing, no sound and no screen it will be power related. It is either your external power supply or the internal power in the computer. If you have another external power supply, try that or if it is the internal power supply you will need a repair person to fix it.
