20 Most Recent ASUS Eee PC 1005HAPU17BU Netbook Questions & Answers
When turning on the netbook, it load then the screen turns black for about 5-10 minutes before reaching the login screen. After logging in, the screen is just grey and stays like that. What's the
Try a system restore/recovery to a date before this issue. Have you done any hardware or software changes or updates? Graphics updates. Shut down, unplug, remove battery, plug in boot and follow this procedure: Please restart your computer, and hold down the F8 key before the Windows logo appears. On theAdvanced Boot Options select Repair your computer, and then press Enter. Select a user name, type the password, and then click OK. On the System Recovery Options menu, click System Image Recovery, and then follow the instructions. Take a look at this procedure from Asus suppot: http://support.asus.com/Search/KSearch.aspx?SLanguage=en&keyword=restore&ps=10&pn=1&st=knowledge
12/16/2012 9:08:59 AM • ASUS Eee PC... • Answered on Dec 16, 2012
Had drivers on usb memory havent got bk up disc howcan i download drivers again
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
9/3/2012 5:28:16 AM • ASUS Eee PC... • Answered on Sep 03, 2012
I need to do a system recovery but don"t want to lose everything
for this you need the windows disk...to recover your datafor further problem you can call www.itechsupportgroup.com Call 1-888-859-3101 for instant support.
5/8/2012 8:49:55 PM • ASUS Eee PC... • Answered on May 08, 2012
I have a eee seashell notebook. Computer says "we
reinstall windows
1/23/2011 8:09:37 PM • ASUS Eee PC... • Answered on Jan 23, 2011
My asus eee pc netbook boots, everything runs fine
Welcome to Fixya
Try to restart the computer again then let the computer boot up to normal mode. Your computer should boot up to normal mode with generic video card settings since you did something to your video card adapter. Then all you have to do is to reinstall your video card adapter driver. That should be the standard process.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
11/25/2010 2:42:40 AM • ASUS Eee PC... • Answered on Nov 25, 2010
My pc has just stopped running the charger light
battrey his already damaged, try replacing them with new battrey ....
6/2/2010 6:55:31 PM • ASUS Eee PC... • Answered on Jun 02, 2010
Always hang up.,how to reformat and restore factory settings...??
How to format your hard drive and re install your operating system.
in order for you to do this you have to (before you format)
1. make sure that you have your recovery cd's or a cd/DVD with your operating system (windows or Mac)
2. try to back up all your information to an external Hard drive or DVD's depends on how much usable information you may have.
3. try to handpic your files to back up because if you do an auto back up you will end up with the same problem again.
-- to do a back up copy all your needed files to an empty folder and then burn them to DVD's or copy to an ext. HD.
4. after you do that (if you have your recovery cd's) insert #1 and restart your computer it will tell you to press any key to start from cd do that and follow directions.
5. when the program shows your partitions go ahead and delete them all, you need to end up with one
6. when you see just one partition go ahead and click continue and it will install your new operating system
7. if you have more than 1 cd it will ask you to insert the next one and so on.
8 after it finishes installing, get the cd out and run the setup process like if you've got a brand new computer, type the information and keep clicking next.
9. at one point you would be on the windows screen and that is it you have a brand new operating system.
Note: take in consideration that when you follow this process, you
erase EVERYTHING from the system including files and programs so after you do this you are going to have to re-install all your programs and copy your docs. back to the pc.
**** If you don't have the discs
check under start-(all) programs - start up- recovery- disk creation.
that (if you have it) will help you to create your recovery disks try to use 2 dvd's if posible if not you may have to get a windows cd to re- install and install drivers and apps.
if it works for you don't forget to rate me
thx
5/26/2010 12:08:32 AM • ASUS Eee PC... • Answered on May 26, 2010
2answers
Wd 11 error code:0xc0000034
The last line of your error message contains the solution: "You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer." Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM • ASUS Eee... • Answered on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM • ASUS Eee... • Answered on Oct 07, 2019
2answers
I recently purchased an Asus
Hello Machatsiduba, It's likely that the network card is capturing some radio signals phones close to your geographical location. Specifically, the Wi-Fi controller can cause this problem; I recommend you follow these links to solve this problem. 1) https://support.microsoft.com/en-us/help/4000460/windows-10-check-wi-fi-drivers-settings 2) https://support.microsoft.com/en-us/help/4000461/windows-10-wifi-problems-home-layout
5/25/2019 12:13:46 AM • ASUS Eee... • Answered on May 25, 2019
Rog 750 g750jw serial location
x2. the ASUS box has a white sticker on the new box. clearly showing this fact. the motherboard, has sticker to ,for the same thing, same answer, in the BIOS info screens, the serial will bet there and a UUID, serial, that Microsoft uses, to block activation. there a mAC too. you did not say why you need this, so lacking context we guess. omg a gaming laptop... ASUS Rog 750 g750jw on laptops in general, its on the bottom of the case on some remove the battery pack and its a sticker inside there. on newer laptops, the deleted stickers (deemed ugly) so is deep hidden. BIOS pages are it. i look at your mobo, and see only stickers on the ram slots so open the ram hatch and look? I SEE ONLY THIS. i redacted it a bit, to make it neutered. PN: not this. PT? i guess not. lower right, side is my guess, on SN. 69N-bla bla sn-rog-lf2mtn200wr504vgnybkj5cw-1-0.jpg
11/5/2018 1:26:46 PM • ASUS Eee... • Answered on Nov 05, 2018
Call Asus support, or info could be in the manual
11/25/2017 7:53:51 PM • ASUS Eee... • Answered on Nov 25, 2017
My Asus Eee netbook keyboard will suddenly for no
see if you can find out why at this link... Asus Eee netbook freeze up Google Search
10/21/2017 1:03:24 PM • ASUS Eee... • Answered on Oct 21, 2017
I was running avast anti-virus while browsing using chrome when I tripped on the power cable and the system shut down. the next time I turned the power on, I got DISK READ ERROR OCCURRED PRESS CTRL+AL
Hello, Weird problem... situation may have nothing to do with what happened. Your hard drive may have core problems. I would run the BIOS diagnostics if able. Also, boot from the OS install DVD and get to a command prompt where you can run CHKDSK. Good Luck, Steve I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
9/30/2017 3:58:53 PM • ASUS Eee... • Answered on Sep 30, 2017
0answers
Asus keyboard typing * instead of p
one or more keys may be stuck
10/25/2016 1:28:01 PM • ASUS Eee... • Answered on Oct 25, 2016
Can't enable wi-fi on Asus x43u laptop
Usually the wireless problem comes with asus laptop when you do not update the wireless driver properly. so you need to go ahead and updated the wireless driver and then you need to reboot your computer. finally your computer will start working fine. for more information you can visit : Tech Support For Asus
9/19/2016 8:29:50 PM • ASUS Eee... • Answered on Sep 19, 2016
ASUS Eee PC 1005HAPU17BU Netbook Logo
10 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
when turning netbook load screen turns
  • Computers & Internet
