20 Most Recent Samsung R430 Notebook Questions & Answers
Have you tried an external display to check it boots? It is an LED display so no inverter to worry about, just the GPU
Samsung R430... | Answered on Aug 25, 2015
try doing a disc clean up and a defrag might help.
or you could have other programmes running in the background that you need to turn off.
try not to have to many running at the same time.
Samsung R430... | Answered on Apr 12, 2015
check on the laptop charger or power source to see of there is power if they are working well,if they are well check power button if its faulty if its working then the problem is the power supply which is faulty
Samsung R430... | Answered on Feb 03, 2015
If you want solution for the problem that your battery is not being charged above 80%, then here's a solution.
Samsung Laptops have a feature to extend the battery life by stoping your battery charging after 80%. If you want a full charge, check the following two steps:-
1. Disable the Samsung Software "Battery Life Extender"
2. Enter the BIOS by keep pressing F2 button just after turning on your system. In BIOS, you will find an option Battery Life Extender(or something), disable it.
after following these steps you are done.
Samsung R430... | Answered on Dec 17, 2013
Flea bay have R430 parts listed. That will give you an idea of part costing then add some labour charges.
Samsung R430... | Answered on Oct 29, 2013
u can not, u will need to reinstall windows from scratch, from CD
Samsung R430... | Answered on Oct 15, 2013
go to programs, cyberlink youcam
this is in power settings - click on the battery icon bottom right hand corner,and then more power options and chose what the computer does on battery or AC power, change it to do nothing and save. change both plan settings it currently uses and then in left hand column chose when computer sleeps, go through them all.
same as mine (left side)? u need to have it replaced, in the mean time just use the touchpad in the same way single or double tap, and it will produce the same effect until u have time for the n hardware fix.
u need to try a complete reinstall of windows from CD/DVD drive.
u may have a HDD problem or just a complete software problem so reinstalling windows will hopefully fix this and u can then at least get into the machine to make more changes.
I have the same computer so let me know the outcome here or at [email protected] I can supply u with a windows CD if needed.
another idea could be to use a removeable HDD to see if it is a hardware or software problem.
this sort of problem needs to be looked at, a few lines explaining don't really help me alot.
download 7zip here if u donyt already have ithttp://www.7-zip.org/download.html
then find the correct driver relating to the problem from here:
http://www.samsung.com/uk/support/model/NP-R730-JT08DE-downloads?downloadName=DR
unzip the file using the wizard in 7zip then run setup.exe and install, reboot and it should work
due to password? if so u need to take out the on board battery for a while, that holds all this info.
does any light come on the bottom of the touchpad when the ac power is connected? if not then there is a connection problem from the power adaptor and the laptop u need a new male AC power adaptor fitted
or
does the green light come on on the power pack when switched on at the wall? if not u need a new one, as it is not sending power to charge the battery or turn on the laptop.
or take to a shop and ask if they have a new battery for it, let them try and get it to come on with a new battery. note -(do not tell them that the charge is not going into it.) if it does come on then my first answer is the solution more than likely - a cheap fix, u could do it yourself if u have a soldering iron as the connection has probably just come lose from the motherboard. the leads often cause the point to move from side to side in the end dislodging it completely from its connections to the motherboard. good luck - let me know or any further questions email me here or at [email protected]
one of three things.
1 check that in the bios settings the WLAN is on or on automatic.
2. once windows is loaded hold down Fn key and press F9, this will turn the wireless on and off.
3. reinstall the WLAN driver from
go down the list and chose camera one its 6mb approx zipped
unzip and then run setup it will fix your problem
u might need to download pkunzip or 7zip to do this, its free just type it in google. do this first before u download the camera zipped file and then when u open it it should all go smoothly, use the wizard within the unzip program.
once unzipped, as stated go to the directory and run setup, follow instructions, reboot and your problem should be solved.
i have a r730, one or two up from yours any questions or need more help contact me at [email protected] or on here
first check audio driver on device manager if there are a problem download correct driver and install .
if driver are correct or not problem go to bios setting and enable audio setting and save .
when you do this your problem were fix 100%
Samsung R430... | Answered on Sep 18, 2013
Samsung R430 Notebook Logo
56 questions posted
Popular Products
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
R Samsung
  • R Samsung
Most Popular Question
samsung r430 screen bezel broken its
  • Computers & Internet
