20 Most Recent
Dell Inspiron 580 Desktop Computer (Intel CORE I3 530 640GB6GB) (DDCWYB8) Questions & Answers
Is the dell inspiron 580 a usb 2.0 or 3.0
I don't think your computer has USB3, because USB3 came after 2009. But that should not stop you from buying an USB3 hard drive. My computer did not have USB3, and I used USB3 drives, long before a bought a USB3 extension card. You always van connect an USB3 drive to an USB2 computer connector. Ans an USB2 drive to an USB3 computer connector. The slowest part in the chain, will dictate the maximum speed. But even with the USB3 drive, now on your computer, the computer can't use the full speed, but if you buy a new computer, the same drive can be used on a much higher speed.
I did put in a USB3 extension card, but it did not help much. My internal computer buss is slowing things down, so even my USB3 drives, most of the time only reach 35 Mbyte/ second. A speed USB2 could reach too. But connecting my drives to newer computers makes them almost 3 times as fast. And with the file sizes I'm sometimes have to put over, that really makes a difference.
If i buy a dell
Yes, you do not need a modem. You connect a LAN cable from the computer to the DSL modem to access your Internet Service Provider.
DISPLAY HAS A YELLOW CAST
First test your monitor to another computer, if it works fine with another computer, then your video graphic card is damaged or the connection port, or cable is bad. and needs to be replaced. If the monitor do the same with the yellow cast with another computer, then your monitor may need to be adjust for coloring in the screen menu, or simply do a auto adjustment with the monitor option. If that donsn't solve the promblem then you need a new monitor.
I have a Dell Inspiron
Hi oconnor,
It does indeed sound like a virus or some sort of malware. The good news is that you can get expert help without paying anything, or not much at least. The web site is called What the Tech and has experts in virus and malware removal. They will give you step by step instruction on how to clean up your system. The site is a donation based forum, they will not charge you anything for the service, after you system is clean you can make a donation if you wish to. Here is the link:
http://www.whatthetech.com/
Hope this helps
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops:
Inspect and clean the air vents and fans
Restart the computer
Update the BIOS and Chipset driver
Download and install Microsoft Windows updates
Run a hardware diagnostic test
Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops)
Improve efficiency to reduce heat
Perform a Windows System Restore
Restore the computer to factory defaults
I want to delete my shtyle.fm account plz help me to delete acoount permanently
I don't know its solved or not but here's the method. Step 1 : Login to your profile of shtyle.fm Step 2 : Move your cursor to the "you option "or "your profile option". Step 3 : There, You will see the link of "Account Settings". Step 4 : Click on that link and you will see "Delete profiles and friends" Option There. Click on it. Step 5 : After that you will see the information that why you should't delete the account and bla bla bla. Step 6 : Just click on the continue button. I highlighted the link in below given image. Click there. Step 7 : Now you will see the box where you can enter the reason why you want to delete your shtyle account and profile. Enter reason or leave it blank and click on delete option. That's It. Your account is deleted. When you try to login with the same credential again you will see this. If you see below given error then your account or profile is deleted.
Source : Youshouldlisten.com
