20 Most Recent
Dell V313w AllInOne InkJet Printer Questions & Answers
There is an error message on my printer that says
Use Service Center to solve printer problems
The Service Center provides step-by-step troubleshooting help and contains links to printer maintenance tasks and
customer support.
To open the Service Center, use one of these methods:
Method 1
If it appears on an error message dialog, click the For
additional assistance, use the Service Center link.
Method 2
1 Click or Start.
2 Click All Programs or Programs, and then select the
printer program folder from the list.
3 Select Printer Home.
4 From the Support tab, select Service Center.
Printhead replacement
If all of your cartridges are good and full of ink and you have done all to clean and still cannot get printer to print a test page then your print head is fubar and in need of replacement. Not cheap and often better to get new printer than replace the print head.
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Only prints one page
Can you delete your printer from your pc and reload it? mine hangs up once in a while too. Just weird gremlins as sometimes it's perfect.
How do I set the printer for "Quick print" or
The easiest way is to do this from Windows. Open the Devices and Printers and select Printer Properties for the printer you want to make the change on. Select "Prefernces..." and change to the desired quality. As an option, add the printer a 2nd time and have one as Draft mode and the other at maximum quality. That way you can just select a printer to get the quality you want.
10/15/2013 12:37:53 AM •
Dell V313w...
Answered
on Oct 15, 2013
