20 Most Recent Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Questions & Answers
2answers
Actualy i dont know how
Hi reetmalhotra,
Canon do supply a wireless setup program for your model which will guide you though the process:
Canon PIXMA Wireless Setup
By clicking the link above you will be taken to this page where you can download the software:
Canon PIXMA Wireless Setup Assistant is a tool which enables you to confirm the access point name and network key required when setting up a wireless LAN connection.
3/3/2021 5:19:09 AM • Canon PIXMA... • Answered on Mar 03, 2021
3answers
Canon MX870 error 6A80
Hey folks.. don't look for the " black square and black rectangle "Here are better instructions.. 1. Turn off the printer. Lift the entire hood so you can see the ink tray. Slide the ink tray over to the left side.* if the ink tray does not slide.. you will have to turn the printer on and then lift the hood ..as the tray slides to the left ... pull the power cord out so the printer shuts off.2. once the ink tray is on the left. follow the ink tray rails to the far right.3. below you should see this "white plastic" tray ( that is the ink tray cleaning mechanism ) it has these black thin plastic tabs sticking up.. ( kind of like a scraper for the ink ).. slide that "white tray" away from you..4. the white tray should snap into place .. you're done !! no more 6A80 error !!
8/30/2020 8:10:10 PM • Canon PIXMA... • Answered on Aug 30, 2020
2answers
Canon mx 922 is offline on mac
Set ip address or conform user group or conform range for signal
2/28/2020 6:12:28 AM • Canon PIXMA... • Answered on Feb 28, 2020
2answers
Canon pixma mx870 error B200
how to repair b200 error code on canon MX870 printer?
1/4/2020 11:32:55 AM • Canon PIXMA... • Answered on Jan 04, 2020
Hi, My cannon MX870 is
@patrick_towl Check out videos on You Tube. Googling this, I also found another site that describes in text, a button-combo procedure.
7/22/2018 4:13:02 AM • Canon PIXMA... • Answered on Jul 22, 2018
My cannon MG5220 printer will
Many printers will not scan over a network, even when they are supposed to. Try connect to it with a standard USB cable and scan to PC directly. If that doesn't work - you have probably got a faulty scanner. If the scanner works OK directly to a printer, then your issue is either LAN/WLAN bandwidth or an unstable IP address. Try fixing the IP Address rather than running DHCP address allocation eg set it at 192.168.x.150 where x is the range value for your network. Then set the printer port address on your devices to the same values and try again.
11/28/2017 1:26:24 AM • Canon PIXMA... • Answered on Nov 28, 2017
2answers
Servise manual Canon printer MX870
Hello, here is the service manual mx870 sm
11/25/2017 6:07:30 AM • Canon PIXMA... • Answered on Nov 25, 2017
0answers
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
5/10/2017 5:45:27 AM • Canon PIXMA... • Answered on May 10, 2017
0answers
My MX870 won't turn on
if no power then the internal power source or control board/ chip has a fault time to read up the trouble shooting section a 1127 page user manual http://content.etilize.com/user-manual/1015675201.pdf
4/30/2016 2:17:06 AM • Canon PIXMA... • Answered on Apr 30, 2016
Print is light and spotty. It has new printer cartridge. Looks like clogged jets.
Printers have an inbuilt programme to clean its ink jets, I would suggest you try it.
3/5/2016 6:43:18 PM • Canon PIXMA... • Answered on Mar 05, 2016
How can i scan multiple pages into one pdf with mx870
Forget all the old postings here. They are not reflective of the 2016 information. FEB 15 2016 For Windows 10 1. Open the Canon IJ Network Scan Utility. (Came with your MX870) on your PC. Make sure it is ENABLED. (Look for icon in the right side of your tray and right click on it.) 2. Open Canon MP Navigator EX Came with your MX870) on your PC. 2a. Click Scan/Import Button at the top. 2b. Click Photos/Documents (Platen) button on right side. 3. Place the first page of your document on the platen. Close lid. 3a. Click the green Scan big rectangular button. 3b. Remove first page of the document, place the second page of the document on the platen, close lid. 3c. NOTE: This time, there will be a small rectangular box in the same large white box that has the small thumbnails of the page of your document that you have scanned. The small box will be labeled "Scan Complete." There will be a note that says, "Scan complete, to continue scanning load the next document and click "SCAN." There are two choices only. "Scan" and "Exit." 4. Repeat step 3 - 3c clicking on the "Scan" button in the Scan Complete box for each page of the document. When the last page is scanned and the thumbnail is in the white box with the rest of the multi-page document, click on the "Exit" button. 5. Use the Ctrl button and choose each of the thumbnails representing the pages of the document you want to save as one file. Be sure they have a yellow frame highlighting each thumbnail, as well as have a small check in the little box at the bottom left of each thumbnail. 6. At the bottom left of the MP Navigator EX window, click on the rectangular box that says, "Save as PDF file." 7. Your multi-page PDF file will be saved in the location you have specified in the settings. If you need the drivers and software for this go to the: Canon Support ' MX Series' PIXMA MX870 site here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx870 Under: Drivers and Downloads, choose "Recommended Downloads" and get this driver and File Name: MX870 series MP Driver Ver.1.06 (Windows) 01/29/16 31.73 MB Then under Drivers and Downloads, choose "Software" and get this software and File Name: MP Navigator EX Ver. 3.15 (Windows 10/10 x64/8.1/8.1 x64/8/8 x64/7/7 x64/Vista/Vista64/XP/2000) 07/22/15 47.72 MB scan-multiple-pages-into-one-pdf-mx870-bias4r3nvd0f3ezi5ng1xfxy-5-0.jpg scan-multiple-pages-into-one-pdf-mx870-bias4r3nvd0f3ezi5ng1xfxy-5-2.jpg scan-multiple-pages-into-one-pdf-mx870-bias4r3nvd0f3ezi5ng1xfxy-5-5.jpg The pics of the page and information are for reference....
2/16/2016 5:35:06 PM • Canon PIXMA... • Answered on Feb 16, 2016
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
339 questions posted
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
am receiving error code 5 145 61 canon
  • Office Equipment & Supplies
