20 Most Recent HP Designjet T1200 Large Format Color Inkjet 44 549 ft h Color 2400 x 1200 USB Plotter Printer Questions & Answers
Problem with "Ink Supply Station" P/NoQ6683-60188. Replace it..
If you are tech guy follow the suggestion:
Error reason: ISS divided in to two units, each unit will maintain that pressure to pump ink to print heads. The part called "rocker" push the elestomer bongo(black rubberized material) to pump ink. This rocker movement sensed by the respective sensors to calculate timely movement. If these sensors malfunction or variations in rocker movement causes error..
Remove/take out Ink supply station, two units of right & left, right unit not working properly, clean sensors & lubricate the drive shaft.. Follow the pics..,
Note: Technically if you are not sound don't do this activity..
2_16_2013_7_45_21_pm.jpg2_16_2013_7_45_46_pm.jpg2_16_2013_7_46_05_pm.jpg2_16_2013_7_46_30_pm.jpg2_16_2013_7_46_54_pm.jpg
HP Designjet... | Answered on Aug 01, 2018
Who did you order the ink cartridge from and is it a genuine HP cartridge
HP Designjet... | Answered on Aug 24, 2017
This could be an issue with paper jam in the printer or out of paper sensor. Open the top cover (with HP logo) and check if any paper is stuck inside the printer, specially in the corners. This could also be an issue related to roll loaded in the sheet slot.
Please click the link below to download the user guide which will help you understand this better.
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c01914944-2.pdf
HP Designjet... | Answered on May 11, 2016
First time are you opened this printer? or else some one attempted? This error indicating that re-used or un supported parts are installed..My suggestion replace with old parts check the error message..then do the trouble shoot. Error 06:00 replace formatter or Hard disc..replace one by one & do the diagnostic test then confirm the part condition, replace the defective part/parts ..But replace with new parts only..
HP Designjet... | Answered on Oct 23, 2011
Media_Axis motor malfunctioning/shut down.
Reconnect the drive motor connections. Perform the paper drive diagnostic,check media advance drive, replace PCA,,
HP Designjet... | Answered on Sep 08, 2011
This can happen due to the firmware on the plotter, even if it happens only with some postscript files.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3980523&prodTypeId=18972&objectID=c02189041
HP Designjet... | Answered on May 05, 2011
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
HP DesignJet... | Answered on May 08, 2020
To solve issues visit https://support.hp.com/in-en/document/c04530811 to get quick support call our Toll-Free 1 888 224 4280
HP DesignJet... | Answered on Jul 30, 2018
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
HP DesignJet... | Answered on Apr 15, 2015
HP Designjet T1200 Large Format  Color Inkjet  44  549 ft h Color  2400 x 1200  USB   Plotter Printer Logo
Popular Tags
23 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
error 59 2 00 in hp designjet t1200
  • Office Equipment & Supplies
