20 Most Recent HP Laserjet P3015X Printer Questions & Answers
if there is a setting , it will be in the printer set up
however if there is not , you have to alter the page size before pressing the print button
HP Laserjet... | Answered on Dec 12, 2017
Hi is your document you are trying to print matching paper size that is in tray 2? sometimes you have a word document that is set to print to tray 2 but the paper in tray 2 is not the right size so hit Ok twice to confirm the size. also the adjustments on the tray may need to be fixed
HP Laserjet... | Answered on Nov 06, 2017
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
HP Laserjet... | Answered on Nov 11, 2015
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancelbuttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison
HP Laserjet... | Answered on Jun 19, 2015
Firstly, you must install proper printer driver into your pc / notebook computer. Then you may enjoy the printing jobs.
HP Laserjet... | Answered on Nov 26, 2014
Make sure that you did not lower the duplex tray. Look into the printer where the paper tray goes and make sure the path is clear. The duplex tray is dropped by pushing on a green lever on the left front of the duplex tray. Simply push the tray up until if clicks and locks in place. This is the only reason I have run into with clients as to why they cannot insert the paper tray.
HP Laserjet... | Answered on Sep 14, 2014
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
HP Laserjet... | Answered on Sep 06, 2014
The printer comes with one main tray which is referred to as tray 2. The bypass tray is labelled as tray 1.
HP Laserjet... | Answered on Jun 03, 2014
Reasons:
1. Teflon Sleeve, use better quality sleeve.
2. Apply good quality of Teflon grease.(Don't apply more or less)
3. Chk Fuser temperature..& connectors..
4. Adjust Fuser temperature in fuser mode..
HP Laserjet P3015X Printer Logo
104 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laser jet p3015 not powering
  • Office Equipment & Supplies
