20 Most Recent Epson Stylus Pro 3880 InkJet Plotter Printer Questions & Answers
Tip
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet...
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Epson Stylus Pro... | Answered on Sep 11, 2015
Download updated software from the Epson website.
Epson Stylus Pro... | Answered on Mar 20, 2014
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Epson Stylus Pro... | Answered on Dec 03, 2012
code 45 is lost connection:
so plug the USB cable to another USB-port on the printer and restart it with unplugging the electric cable behind. plug it in again and put the printer to "on"
- most probably then it will see the computer again
Code 45 Currently this hardware device is not connected to the computer epson-printer-error-codes-wutfveiel3ypko01ydor435x-4-0.jpg
Epson Stylus... | Answered on Jul 25, 2020
Google (Epson)(model)(manual) without parens and proceed as directed.
Epson Stylus... | Answered on Aug 25, 2019
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
Epson Stylus... | Answered on Jul 30, 2019
On most Epson printers the Adjustment program can be accessed via the printers interface, without need to do it via a pc. Without knowing the model it is fairly difficult to answer this question more fully. However if you have a manual or can download the manual from epson.com, there will be a chapter on manual head cleaning and adjustment proceedures.
Epson Stylus... | Answered on Jul 19, 2019
Epson Stylus Pro 3880 InkJet Plotter Printer Logo
21 questions posted
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
jasbo
jasbo
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
service call error 1101
  • Office Equipment & Supplies
