20 Most Recent HP Officejet 6500 AllInOne InkJet Printer Questions & Answers
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs? How to Get Started with VB NET Word
11/1/2019 11:07:18 PM • HP Officejet... • Answered on Nov 01, 2019
I want reset my hp officejet 6500A
Hi. To reset an HP Officejet 6500 E709a or 6500 Wireless E709n, follow these simple steps: 1. Press the (*) and (#) buttons on the printer control panel at the same time and let go. 2. Use right and left arrows to scroll trhough menu and select "Resets" 3. Select "Semi-Full" reset and printer will shut off in a few seconds. 4. Unplug the printer from wall and wait 30 seconds. 5. Plug in the printer, Turn printer on and selec basic settings. Your printer is now reset!!! If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
11/1/2019 11:05:20 PM • HP Officejet... • Answered on Nov 01, 2019
2answers
Semi full reset 6500
HiWant to reset the printer?Check this video out.Hope it helps.Thanks!
10/8/2019 4:57:02 PM • HP Officejet... • Answered on Oct 08, 2019
3answers
Officejet 6500 color balance
On HP 6500 printers, remove screen and try heating the connection elemants with hair dryer or something similar. Nothing to hot. The led bars should restore. Here's a link on how to remove HP 6500. Do same for 6500A model, but screen is a bit different, so check out the other video for HP 6500A and 6500A plus printers: HP 6500:
1/30/2019 6:09:54 PM • HP Officejet... • Answered on Jan 30, 2019
3answers
New ink only prints pink and black?
Try soaking printhead in the cleaning solution and it will resolve the issue. Check out the video on how to repmve printhead below. Put it in about half inch of solution which is 50% water, 40% window clening solution like windex, and some ammonia or rubbing alcohol.
1/30/2019 6:05:34 PM • HP Officejet... • Answered on Jan 30, 2019
2answers
How do I tell ink levels
If you have Windows 7 you can check this by clicking on the "Start" button at the bottom of the screen, click on the "HP" folder and click on "HP Solutions Center". A graft will come up showing you the printer cartridges levels. Click on the small graft chart at the top right of the screen and the graft will enlage and show you exactly the staus of the ink levels. Click "Print" at the bottom of the screen and it'll run a print test. All 4 cartridges need to be above the "Low" level. It only takes one of them to mess up the print.
3/8/2018 3:27:14 AM • HP Officejet... • Answered on Mar 08, 2018
I, have a hp6500 and when I, try to print my wells fargo bank statement I, only get lines and no despriction of item of items or amounts, what could be wrong? Coleen
Does this happen with anything else you try to print, or is this the only thing that doesn't print correctly? If this is the only thing, then it's not your printer. Try downloading the statement and then printing it. You'll need Adobe Reader.
9/3/2016 11:12:57 PM • HP Officejet... • Answered on Sep 03, 2016
Hto increase print size
You have to change print size by choosing a larger font in the software you used to produce the document.
8/11/2016 4:55:17 PM • HP Officejet... • Answered on Aug 11, 2016
When I try to print business cards on Avery cardstock, colors print but NOT BLACK!
I would suggest using the printers own head cleaning programme
3/5/2016 1:43:12 PM • HP Officejet... • Answered on Mar 05, 2016
How to fix no paper message on hp officejet 6500
if there is paper take it out and put it back in and move around anything that move even a little bit, it sounds like something didn't connect, if it works ok don't worry about it.
7/31/2014 7:20:28 PM • HP Officejet... • Answered on Jul 31, 2014
LOW INK MESSAGE AFTER A REFILLED CARTRIDGE
cartridges have chips, you need a cartridge with a special chip that resets each time. These can be bought on ebay or amazon. You cant refill factory cartridges with oem chips.
5/28/2014 10:33:51 AM • HP Officejet... • Answered on May 28, 2014
Not printing the entire page. Approximately one quarter of the page not printing, across ways.
I would listen to the response to Geraldine Watts by Handyman back in 2007. Not printing sounds like dirty heads that can be lightly wiped by just a water damped qtip. This helped me at one time. Black vertical lines are fixed by pulling plugs for a couple of minutes (resets machine). It could also be a bad cartridge but I doubt it. I would never waste money on buying parts because the new printers to purchase are cheap enough. My 6500 broke when I pulled out several pieces of paper and then got an ink failure error. No fix for this. I then bought the 7520. photosmart and I am glad my 6500 broke. I bought direct this time from HP at $149 (hp matched a best buy sale) as well as buying their warranty for $34 that covers next day replacement and any phone questions I might have for 3 years. I love hp photosmarts only because they are the 'king' on photo quality but I hate the reps charging if you are out of warranty. If HP offered help to those out of warranty they would then have no competition in the printer world. I buy my inks from local stores like staples. Good luck with your machine.
4/8/2014 11:17:50 PM • HP Officejet... • Answered on Apr 08, 2014
HP Officejet 6500A Printer problem. Ser.No.
Try reset the printer after you have cleaned the printheads. http://www.youtube.com/watch?v=31TbWMrTaFk
10/5/2013 5:23:39 AM • HP Officejet... • Answered on Oct 05, 2013
2answers
Ink system failed
Not sure exactlly what you mean but you may want to check the ink and the printer heads by doing the following checks: More than likely your running out of ink. Check the ink levels first.If you have Windows 7 you can check this by clicking on the "Start" button at the bottom of the screen, click on the "HP" folder and click on "HP Solutions Center". A graft will come up showing you the printer cartridges levels. Click on the small graft chart at the top right of the screen and the graft will enlage and show you exactly the staus of the ink levels. Click "Print" at the bottom of the screen and it'll run a print test. All 4 cartridges need to be above the "Low" level. It only takes one of them to mess up the print. If you've got plenty of ink try cleaning the printer head by:Click "Setup" (just below and left of the LED screen) on the printer.Scroll the Led screen to "6. Tools". Hit "OK"Now scroll to "2. Clean printhead". Hit "OK".This should do it..
5/24/2013 8:46:16 PM • HP Officejet... • Answered on May 24, 2013
Can the light be change in this printer?
Hi,Try connect the printer to different wall outlet.Regards,Sean
4/22/2013 3:54:06 AM • HP Officejet... • Answered on Apr 22, 2013
Black ink turning red
CARTRIDGE IS ABOUT TO RUN OUT
2/26/2013 1:04:24 AM • HP Officejet... • Answered on Feb 26, 2013
HP Officejet 6500 AllInOne InkJet Printer Logo
Popular Tags
96 questions posted
Clive
Clive
Ben Johnson
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
not printing entire page approximately
  • Office Equipment & Supplies
