20 Most Recent Avantco Refrigeration Avantco GDS47 White 2 Door Glass Door Merchandising Refrigerator with Sliding Doors 120V - 44.75 Cu. Ft Questions & Answers
same thing happened to me take note that they used a manual trans bellhousing so you have to specify a manual trans starter different amount of teeth on flywheel
Air Tools &... | Answered 3 days ago
It is quite normal for the output line to exhaust into the atmosphere until the new pressure is achieved when reducing pressure. If it continues to leak the regulator is faulty.
Air Tools &... | Answered on Oct 24, 2020
If the air pressure in the tank doesn't reach the regular cut out pressure level and since then the air compressor is not able to turn off as the pressure never reaches the cut out pressure level, then look to the intake valve or and internal gasket leak as the possible source of the problem.
Air Tools &... | Answered on Oct 19, 2020
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
If you can't find a manual and the manufacturer or dealer can't help, you might find the information in an oil supplier's application catalogue.
Air Tools &... | Answered on Oct 17, 2020
The service light is not a warning. Warning will go out when problem is fixed. Service indicator is based on hours of operation. Codes are only available thru service techs or Atlas Copco if they will give it to you.
Air Tools &... | Answered on Oct 05, 2020
a good tip with O rings is just too replace them all
you can get a kit of them on ebay for about £5 or so....all different sizes
Air Tools &... | Answered on Sep 18, 2020
36 gallon is not a big volume. Normal water pressure in our houses is generally between 40 and 60 PSI. Most people prefer something right in the middle around 50 PSI.
Air Tools &... | Answered on Sep 07, 2020
Type in the maker and model of your compressor into google and find a supplier and order one.
Air Tools &... | Answered on Aug 09, 2020
Bad discharge check valve.. replace valve!!
Air Tools &... | Answered on Jul 31, 2020
Avantco Refrigeration Avantco GDS47 White 2 Door Glass Door Merchandising Refrigerator with Sliding Doors 120V - 44.75 Cu. Ft Logo
0 questions posted
Top Avantco Refrigeration Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
Tom Chichester
Are you an Avantco Refrigeration Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Avantco Refrigeration Air Tools & Compressors
Most Popular Question
problem craftsman 30
  • Air Tools & Compressors
