20 Most Recent
Dell E198FP 19" LCD Monitor Questions & Answers
There is no sound in my system
Pls check if sound icon is seen in your task bar near time display,if not then add sound driver if it is present then check whether it got mute by mistake
There is no sound in my dell e198fp
Either is problem with speakers or with your software. So just right click on speaker icon in notification area and open playback devices and see if you can see your speaker. and then right click and then select test. If you cant see your speaker in the list, you probably have driver problems and u need to install all necessary audio drivers, if you can see it bt cant listen anything, there is a prob wid ur speakers.
My on / off button
more of a mechanical issue already. if it is within warranty, request a replacemen from Dell
When I first turn on
Make sure you are on the correct video setting on the monitor using the menu button.
If you are hooked up to dvi you need to make sure the monitor is on the dvi component.
VGA same thing.
Hope this helps
Positive feeback always welcome
No power
Hello
Mostly it was the power supply problem need to be handled technically, it is recommended that the monitor may be repaired by a qualified technician,
at your level you can check the power cord and fuse inside the power supply
Good luck
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
