20 Most Recent
Dell E2210 22" Widescreen Flat Panel Monitor Questions & Answers
We have rolled out Dell
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Monitor screen is perfect , but there is one 1mm
It would appear that the monitor is going bad. If it is within a year of purchase, contact dell for a warranty replacement. If not, use it until it dies. It depends, but usually bad pixels and lines like this will spread rather quickly.
Hello, I am using a 22 inch Dell LCD monitor and
First thing you need to do is to change the signal cable and try the monitor on another PC to determine if the problem is with monitor or something external to it.
Please share results of test to help you further.
Samir
Black strip on top and
Reset the resolution to be higher.
Many flat panel screens must work at their native resolution to be at their best.
I m not getting any
It could be the light itself has gone bad. If it's no problem, just keep using it.
If you don't have enough to keep you busy, you can take it apart and replace the LED.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
