20 Most Recent
Acer P205H Widescreen LCD Monitor Questions & Answers
Hello the problem I have
well it depends, do you know how to check the drivers for the display in Windows? which version of Windows do you have? I would suggest to start looking at the resolution, see if the drivers are up to date for the video card, also I suggest hiring a professional if you are not sure.
Hi dear experts - I
Just use the recommended resolution settings for your computer. See image below.
I do not like the energy feature. The screen goes
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Navigate to the Windows Control panel.
1.)Click Start, then click Control panel.
2.)Double Click Power Options.
3.)On the Power Schemes Tab, you will see the option to turn the monitor off.
4.)You may set the Turn Monitor off option to as long as you wish!
5.)Click Apply.
6.)Click Ok.
Thanking you kindly
damnor01
I have my acer p205h
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
HP monitor keeps saying "monitor
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
