GE Immersion... | Answered on Jan 10, 2014
GE Blenders | Answered on Mar 31, 2020
GE Blenders | Posted on Jan 23, 2019 | Be the first to answer
GE Blenders | Posted on Sep 10, 2017 | Be the first to answer
GE Blenders | Posted on Aug 10, 2017 | Be the first to answer
GE Blenders | Answered on Jun 14, 2017
GE Blenders | Answered on Jun 07, 2017
GE Blenders | Posted on Jan 04, 2017 | Be the first to answer
GE Blenders | Posted on Aug 24, 2016 | Be the first to answer
GE Blenders | Posted on Aug 26, 2015 | Be the first to answer
GE Blenders | Answered on May 21, 2015
GE Blenders | Posted on Dec 16, 2014 | Be the first to answer
GE Blenders | Answered on Nov 25, 2014
GE Blenders | Answered on Nov 22, 2014
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the spraying arm or the pressure pump can be defective .It is important that you look for the noise with a good inspection lamp. Manually turn the spraying arm and the motor and listen for the noise, if so the motor bearings, the arm shaft and fittings must be checked. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of spraying arms check for tips on this visual link:
Thank You for using fixya
GE Blenders | Answered on Nov 08, 2014
1 questions posted
8 Questions
2 Questions
4 Questions
1 Questions
2 Questions
