20 Most Recent 3300l 2way Lcd Security System Questions & Answers
My movement sensor will not activate when veh is rocked, but the internal movement sensors work on entering,
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today They have full manuals and it's verrrrry cheap and mine I got free in offers 3rd time I also had an issue with the file so the girl replaced it in 30 mins there is one more but i don't remember its name it was 2 years back bitman something link this Try it out brother
1/31/2019 8:43:45 AM • 3300l 2way Lcd... • Answered on Jan 31, 2019
Does the avital 3300L support remote start?
for heavy machinery cars etc. luckily there are many websites that can help you repair for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic tried and tested !
1/24/2019 9:58:28 AM • 3300l 2way Lcd... • Answered on Jan 24, 2019
Avital alarm won't arm/disarm.
My remote will not unlock my truck or disarm and I put in New batteries. What do I need to do
7/29/2018 8:04:42 AM • 3300l 2way Lcd... • Answered on Jul 29, 2018
Mustang 1967 and where do i plug the yellow wire? Where can i get 12v in run and in crank position but not in off position
There is an open switched accesory fuse location on the fuse block. Yours may still be on the headlight switch if not visible on the firewall. Or you can attach to the radio 7 Amp fuse. You will not be able to get both run and start together on one wire under the dash. You will need to add a blocking diode to any wire that runs to the "I" terminal on the starter solenoid- this is to keep it from bypassing the ignition resistance wire to prolong point life which you would do if simply wiring straight to that terminal. You would need a silicon rectifier of suitable current carrying ability for the alarm, and then any wire you run out to that location "I" you would attach the banded end of the rectifier to that terminal.
10/29/2012 5:57:08 AM • 3300l 2way Lcd... • Answered on Oct 29, 2012
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
  1. Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
  2. Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
  3. Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
  4. Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
  5. Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
12/26/2022 2:31:43 PM • Avital Vehicle... • Answered on Dec 26, 2022
Remote starter. How can I reprogram it?
Wheel Bands get the best rim edge protectors
9/21/2021 5:05:27 PM • Avital Vehicle... • Answered on Sep 21, 2021
2answers
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter: Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
7/13/2021 10:20:14 AM • Avital Vehicle... • Answered on Jul 13, 2021
2answers
1-way avital 4111 remote. How can I reset?
sadly I never heard of that make here in usa
4/24/2021 11:57:08 PM • Avital Vehicle... • Answered on Apr 24, 2021
We haven't we have an Avital 3200 remote start and the car will not start after changing the battery and we do not have the remote starter fob is there a reason the car won't start due to the remote start and the battery being unhooked?
Yes, your antitheft system need resetting because you disconnected the battery. Because you have an aftermarket remote starter, get the installer to come out to you and reprogram everything. Number 1 tip. When changing a battery, always maintain a 12 volt supply during changeover using a battery tender, the existing battery with jump leads, or a special attachment that goes into the cigarette lighter.
2/17/2021 3:09:14 AM • Avital Vehicle... • Answered on Feb 17, 2021
I am looking for a manual book for avittalking 474S
Contact Avital directly to request the manual.
2/2/2021 2:01:12 AM • Avital Vehicle... • Answered on Feb 02, 2021
I have just had an avital 5103L installed on my truck and when I start it with the remote in the morning the alarm goes off. only when cold
Get a meter and connect it at the battery terminal connectors while somebody starts the truck. Don't connect directly to the battery posts. If you get a big voltage drop, it might be the connectors not cleaned or tightened properly, or could be the battery. Many car alarms sound when the voltage isn't high enough. Also when you had the avital installed, they had to disconnect the battery, so it could be that.
6/14/2020 9:11:37 PM • Avital Vehicle... • Answered on Jun 14, 2020
My avital 3100lx doors won't lock I have to do it manually to each door
Central door locking motor in the drivers door is faulty!
6/7/2020 3:14:31 PM • Avital Vehicle... • Answered on Jun 07, 2020
2answers
I have an avital 7111L that no longer works, despite replacement of the battery. What do you suggest I do next?
I would replace it, they are available on line and not that expensive, Good Luck
7/31/2019 5:33:57 AM • Avital Vehicle... • Answered on Jul 31, 2019
Avital 5303l when remote starts activates, it sticks on starting sometimes and starter keep spinning off.
When the car starts the remote start unit either recognizes because of voltage increase or begin rpm. Either the rpm sensor is not connected properly for the first, or your choice of defective remote start unit or alternator not charging.
4/23/2019 10:39:42 AM • Avital Vehicle... • Answered on Apr 23, 2019
My Avital 4300 is randomly unlocking the doors. Car off or running. It will do it every few minutes even after they are unlocked. All the remote functions work.
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help thanks
3/21/2019 6:40:36 PM • Avital Vehicle... • Answered on Mar 21, 2019
My 7111l avital remote will not start my car it just flashes a green light on the remote
Sounds like battery are remote bad.
3/7/2019 5:50:51 PM • Avital Vehicle... • Answered on Mar 07, 2019
3300l 2way Lcd Security System Logo
8 questions posted
Top Avital Vehicle Parts & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Avital Vehicle Parts & Accessories
Most Popular Question
mustang 1967 plug yellow wire get 12v
  • Vehicle Parts & Accessories
