20 Most Recent Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Questions & Answers
Msjsod sksjsid ejdhdhsi sksjd slkkdim curiousn
Comfort Zone... | Answered on Feb 03, 2019
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Comfort Zone... | Answered on Dec 30, 2017
Here is the easy way to find out. For a few dollars, you can buy a wattmeter of the type you plug in the wall and then plug your appliance into the meter. These meters will tell you the current power consumption, the accumulated power consumption, and can be programmed to automatically show you the cost-per-hour (or day, etc) to run your appliance. You can use them on any appliance. They have a simple digital read-out. Shop around to find one that does everything you want to know. Some have wattage limits, so be sure it will be enough for your heater. Heaters use a lot of power (watts).
Comfort Zone... | Answered on Dec 08, 2016
well obviosly he heater has electrical fault seek electrician, the lights not coming on means electrical fault on heater if new get replacement under warranty if not get electrician to fix for you do not attempt to fix electrical problem if your not a electrician or a restricted electrician, maybe an appliance fixing shop may be your best place to try but it sounds deffinatly electrical
Comfort Zone... | Answered on Mar 21, 2016
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Comfort Zone... | Answered on Feb 24, 2015
What type or heat is it
Comfort Zone... | Answered on Feb 20, 2015
Heaters Comfort Zone from Howard Berger
here is the website for the manual. just look for the model you have.
Google is your friend.
Comfort Zone... | Answered on Nov 14, 2014
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
Comfort Zone... | Answered on Nov 11, 2014
it is themosta, overheat protector , or bad plugin
Comfort Zone... | Answered on Nov 23, 2013
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Comfort Zone... | Answered on Jan 01, 2013
Good day, Doctor.
First, have you tested the wall receptacle that the heater is plugged into? Have you plugged a lamp or other electric appliance into it, to see if it's working? If nothing else works in that receptacle check for a tripped circuit breaker in the panel box of your home.I f there is one tripped, make sure nothing is plugged into the offending receptacle and reset the breaker, by turning it on. If one is tripped, now you need to figure out what tripped it. Was it the heater? Probably so. In any event, plug the heater back into the receptacle and turn the heater on. Did it trip the circuit breaker again? If so, there is an electrical short in the heater. Since you have only had it for 3 months, I would assume it's still under warranty. If so, follow the instructions in the Owners Manual about returning it to the manufacturer for repair or replacement.
Hope this helped to solve your problem.
Comfort Zone... | Answered on Feb 12, 2011
There has to be a tag on the unit that can answer your question. On this tag you want to look for the run load amps. (RLA) Thats your answer.
Comfort Zone... | Answered on Jan 15, 2011
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Comfort Zone... | Answered on Jan 14, 2011
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Logo
30 questions posted
Top Comfort Zone Heating & Cooling Experts
Marvin
Marvin
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort Zone Heating & Cooling
Most Popular Question
just want manual cz7007 not one
  • Heating & Cooling
