20 Most Recent
Sony Cyber-shot DSCH55 Digital Camera Questions & Answers
Hi, my Cyber-shot DSC-H55 is
for all those who c.32.01 error is an error related to contacts camera card reading virtually fail to read the card. for this problem must disassemble the camera and exert a little pressure on each contact then to reinsert the card and restart the camera
My sony cyber-shot DSC-H55 worked
I dropped my camera, it worked OK for some time then now it shows a black dot image on the viewing screen and on the pictures I take out? what is this, a major problem?
Won't load photos onto computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Every time I am getting
Hello, please can you use your camera to format the card? after the formating it will be alright.
The viewing screen is black...
hello
You may have inadvertently pressed the DISP button. This turns the display or screen on/off.
The button is probably the up button on the back. try holding that in when the camera is on.
Hope this helps.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
SONY DSC-S40 RESET IT SELF.
If you have already cleaned the lens gears and the issue persists, it is possible that the lens electric motor is not working properly. You can try resetting the camera to see if it helps. Here are the steps to reset the Sony DSC-S40:
- Turn off the camera and remove the batteries.
- Wait for a few minutes before reinserting the batteries.
- Turn on the camera and see if it works.
If the camera still does not work, it may be a hardware issue and you may need to take it to a professional repair service or contact Sony support for further assistance.
2/26/2023 2:52:49 PM •
Sony Cameras
Answered
on Feb 26, 2023
