20 Most Recent HP Pavilion 14-c010us Chromebook 14-C010US PC Questions & Answers
Tip
How To Fix Your Chromebook If It Won’t Turn On
More users are reporting that their Chromebooks are not turning on or the screen stays black. For some the problem comes and goes but for others their machine just stays off all the time. If your Chromebook doesn't turn on there is a few different problems that can be the cause.
This article will go through all the possible causes. I've arranged them in order from simplest to fix to most complex so that you can go through them one by one until your Chromebook turns on again.
So just try each fix and stop when your Chromebook turns on! Cheers!
Fix #1: Connect Your Chromebook To Power
Let's start with a very simple solution that worked for one of my customers at my computer shop. Simply take your Chromebook, plug it into the wall power outlet, and try to turn it on.
If that doesn't work no worries move onto Fix #2.
Fix #2: Power-Cycle Your Chromebook
  1. Unplug your Chromebook from power.
  2. Remove the battery is that is possible on your model of Chromebook (it isn't on most Chromebooks)
  3. Press and Hold the power button for one whole minute.
Now try to turn on your Chromebook.
Fix #3: EC Reset Your Chromebook
Fix #4: Let Your Chromebook Charge For A Few Hours
If the Chromebook is very low on charge it may just need to charge. Let it sit plugged in and charging for around four hours. I suggest leaving it plugged in over night.
Try turning it on in the morning.
Fix #5: Disconnect Battery And Power-Cycle (Advanced)
Most Chromebook machines have a built in battery that is sealed inside. However most of the batteries are not that difficult to reach if you have a screwdriver and are careful.
Look up a disassembly video for your chromebook model on youtube and watch it to see where the battery is located.
  1. Unplug your chromebook.
  2. Open your chromebook to get to the battery.
  3. Disconnect the battery cable.
  4. Carefully move the chromebook so that you can reach the power button. Press and Hold the power button for one minute.
  5. Re-connect the battery cable. Make sure the connection is secure.
  6. Close up your chromebook. Plug it in.
Try turning it on now.
or this link might help you out some more.
chromebook acer 14 but it will not turn on Google Search
on Dec 03, 2017 | HP Pavilion 14-c010us Chromebook...
Default Login Id & Pass will be printed on your dish router.
Open the web browser &go to the page using the add printed on the router, followed by Login Id & pass.
There you will have the option for resetting the pass.
Finally reboot the router.
HP Pavilion... | Answered on Apr 27, 2016
OS is corrupt and needs re installation/repair.
HP Pavilion... | Answered on Mar 12, 2015
Tip
How reset/reboot a HP Chromebook?
Press the Esc, refresh, and power buttons, at the same time., you should see a yellow ! mark. Then press Ctrl +D. ...Then press enter to begin...Screen shows a red ! mark, Press Ctrl+ D again, this deletes all local data and reboots your chromebook... It could take upto 15 min. to reboot. Ellen
on Jan 31, 2015 | HP Pavilion 14-c010us Chromebook...
Hi donald,
here i think the solutions you looking at..
microsoft About Chromebook
thanks,
HP Pavilion... | Answered on Jan 24, 2015
The font changes need to made under settings, then advanced settings. See this Google webpage.
Change text image and video sizes zoom
HP Pavilion... | Answered on Jan 22, 2015
on Google type anti-malware and chose the free trial software from cnet and scan your computer also there is Kaspersky after you use them just go to your ad and remove programs and delete them.
HP Pavilion... | Answered on Jan 04, 2015
Applications > system tools > preferences > system settings > mouse and touchpad > enable touchpad.
Please try and let know.
HP Pavilion... | Answered on Dec 25, 2014
Chrome books are notoriously bad hardware. Poor graphics and low amounts of ram because they are built to run Linux, which does not require all the power that windows does. Linux itself is a decent system to run on, but if you have a windows 7 disk you'd probably be happier with 7 than the Chromebook linux. But, if you dont have a problem with the OS itself then I'd suggest another refresh. Malware sucks: It gets into your root files and watches everything you type. it is possible someone IN turkey stole your credentials and is logging in with them in attempt to gain access to your banking or credit card info. I would report my info as stolen to the bank, get new cards and etc, and wipe/reload the OS, and before doing *anything* online, get some protection. I believe Avast! antivirus will run on a linux setup, and also you should get adblockplus. www.adblockplus.org
HP Pavilion... | Answered on Dec 08, 2014
Take the machine to a local computer repair professional and have the machine cleaned of viruses. If you are in the northeast Kansas area, let me know and I will be glad to help you resolve this.
HP Pavilion... | Answered on Oct 18, 2014
What email software are you using?
HP Pavilion... | Answered on Aug 23, 2014
Click the "Need help?" link on the Gmail sign-in screen.
HP Pavilion... | Answered on Aug 04, 2014
Medco was recently bought out by ExpressScripts. Try going to their page instead.
HP Pavilion... | Answered on Jan 20, 2014
If you TV has an hdmi in then all you would need is an hdmi cable...if it doesnt then youll need an adapter to convert to what ever inputs your TV has
HP Pavilion... | Answered on Dec 09, 2013
buy an hdmi cable and connect one end to the chromebook and the other into the back of the tv
HP Pavilion... | Answered on Dec 07, 2013
on the bottom right side of your screen where the time shows right click on it with your mouse go up the list that pops up to adjust clock this will allow you to adjust it where it needs to be also make sure its in the right time zone
HP Pavilion... | Answered on Nov 10, 2013
Try pressing Ctrl+Shift+Q, then logout user and log back in with your user.
Taken from here
HP Pavilion... | Answered on Sep 29, 2013
HP Pavilion 14-c010us Chromebook 14-C010US PC Logo
Popular Tags
27 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
all problems having chromebook ve now
  • Computers & Internet
