20 Most Recent Fellowes PS60-2 Shredder Questions & Answers
0answers
How do i get the guides for the paper
You need to be more specific and or upload a photo of where you are referring to.
12/19/2014 9:17:31 PM • Fellowes PS60-2... • Answered on Dec 19, 2014
Red light and green light on but motor will not
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
11/3/2013 4:07:19 PM • Fellowes PS60-2... • Answered on Nov 03, 2013
0answers
PS-60 will not shred automatically-I have to turn
I think the paper feed limit switch may be jammed disabling auto operation. Take precautions to unplug before opening up to inspect for jammed limit switch.
8/29/2013 12:39:57 PM • Fellowes PS60-2... • Answered on Aug 29, 2013
Ar there replacement parts for the paper guides?
put shredder rollers together
3/31/2011 5:46:50 PM • Fellowes PS60-2... • Answered on Mar 31, 2011
The paper is constantly getting jammed up in the
these shredders only can handle 2 or 3 sheets max. also using WD-40 or any light machine oil will help the process
12/16/2010 4:16:20 PM • Fellowes PS60-2... • Answered on Dec 16, 2010
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
7/7/2010 5:42:25 PM • Fellowes PS60-2... • Answered on Jul 07, 2010
Red light on as well as green,what is the red
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
7/6/2010 4:09:59 PM • Fellowes PS60-2... • Answered on Jul 06, 2010
Shredder makes noise, sounds jammed
If it has a reverse function, you should try that to un-jam it.
4/20/2010 11:11:54 PM • Fellowes PS60-2... • Answered on Apr 20, 2010
Will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
8/22/2009 6:06:02 PM • Fellowes PS60-2... • Answered on Aug 22, 2009
Shreeder broken
Here you go buddy http://www.fellowes.com/Fellowes/Materials/Documents/ps60-2_60c-2_2005manual.pdf
12/2/2008 10:41:16 PM • Fellowes PS60-2... • Answered on Dec 02, 2008
2answers
Can I run goo gone through my paper shredder to clean stickiness without dismantling it?
Yes you can, you can also spray it with WD40, leave it an hour, spray it again and run a few sheets of plain paper through it. WD40 is kerosene based.
11/15/2022 2:26:17 AM • Fellowes Office... • Answered on Nov 15, 2022
Powershred 99Ci. Does it have a reset button?
No, but there is an interlock that ensures the collection bin is fully inserted. https://assets.fellowes.com/manuals/99Ci_409366%20090215%20FS%201L.pdf
12/31/2020 5:19:00 PM • Fellowes Office... • Answered on Dec 31, 2020
Fellowes PS60-2 Shredder Logo
Popular Tags
20 questions posted
Top Fellowes Office Equipment & Supplies Experts
David Shaub
George Mclaughlin
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Fellowes Office Equipment & Supplies
Most Popular Question
red light green light but motor will not
  • Office Equipment & Supplies
