20 Most Recent
Mitsubishi X490U Multimedia Projector Questions & Answers
We have our xd49ou in
Hi... from what I know, that unit has a native resolution of 1024x768 and max resolution of 1280x1024, so the first thing you want to make sure of, is that the source you're connecting to it as a maximum resolution of 1280x1024... Ideally 1024x768 since it will give you a better quality image because of the LCD panels that are built in that resolution. Next thing, make sure you use cables that haven't been abused. (Ex. Cables that might have been stepped on or snapped in doors, windows.) If that doesn't help, try giving me some more information on your setup. (What are you trying to connect and how are you trying to connect it.
Green "halo" or haze on
Hello.
You may just need an adjustment. Try a manual focus adjustment on the green crtby using the Image menu.
To adjust
the red-green color balance of the image : Adjust TINT in IMAGE menu. Press the % button to increase
the amount of green in the image and the $ button to increase the amount of red in
the image.
Hope this helps.
I have an Mitsubishi X490U Multimedia Projector -
This unit needs a new Optical block, most likely more than a new projector
check out projectorsuperstore.com for a replacement
by the way, your $10,000 projector only has 2600 lumens, a new/refurbished unit will have 4000 lumens for less than 25% of the cost of your unit
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector.
You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase.
It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
Hi. I have two
Cartridges go dry and are not usable. Get new cartridges and try again.
