20 Most Recent Mitsubishi SL4SU ColorView Multimedia Projector Questions & Answers
It has a magnify feature on the remote I think. You can reset the machine by holding down power computer and video buttons for a long time.
Mitsubishi SL4SU... | Answered on Nov 26, 2013
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Mitsubishi SL4SU... | Answered on Oct 03, 2013
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Mitsubishi SL4SU... | Answered on Mar 13, 2013
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
Mitsubishi SL4SU... | Answered on Jan 10, 2013
what is the status and power doing because there is no information here
Mitsubishi SL4SU... | Answered on Dec 09, 2012
go through the sources, Computer,Video,Svideo
s video doesn't carry sound so you will have to use phono plugs too
Mitsubishi SL4SU... | Answered on Dec 08, 2012
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Mitsubishi SL4SU... | Answered on Nov 21, 2011
press menu then move to signal and the shutter options are there
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for 5 seconds.
OK
Mitsubishi SL4SU... | Answered on Sep 25, 2011
ok make sure its nt to close or far away and the focus ring should be in the midle to find out how to get a good focus hook up a laptop and search google for projector focus chart and use that and blam should be focused
Mitsubishi SL4SU... | Answered on Sep 21, 2011
Reset the Bulb life. Every time bulb changed need to reset it to bring it back to 0 hour.
If you go into the menu of the projector.
Find the lamp status or info command.
It will tell you the current information.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Mitsubishi SL4SU... | Answered on Feb 20, 2011
It could be that one of the fans has broken you will be able to hear them because there are 5 in there. if you are under warantee send it back if you are technically minded take it apart and watch which fan doesnt start then order from mits or from a local supplier,.
Mitsubishi SL4SU... | Answered on Jan 02, 2009
make your pc or laptop start first and then the projector.
Mitsubishi SL4SU... | Answered on Mar 18, 2008
XD550U is the upgrade vision of XD500U, they are almost same,
i have xd500u service manual, you can get if for reference.
Mitsubishi... | Answered on Sep 08, 2020
Mitsubishi would be a possible source
Mitsubishi... | Answered on Nov 27, 2019
Request from Mitsubishi
Mitsubishi SL4SU ColorView Multimedia Projector Logo
24 questions posted
Top Mitsubishi Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Office Equipment & Supplies
Most Popular Question
yellow spot
  • Office Equipment & Supplies
