20 Most Recent
Mitsubishi XD480U Multimedia Projector Questions & Answers
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
What 2 buttons other than the Power button
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow
button, Right Arrow button, and POWER buttons on the control panel ALL
AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
After replacing the lamp in
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector.
You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase.
It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
