20 Most Recent Ultra Linear UL801 Car Amp Questions & Answers
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Ultra Linear... | Answered on Mar 25, 2010
E6 error orient 1.5
Car Audio &... | Answered 2 days ago
Request the diagram from the manufacturer/distributor.
Car Audio &... | Answered on Jul 05, 2020
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Car Audio &... | Answered on Jun 30, 2020
KNOW OF NOTHING CALLED A KEENWOOD
Car Audio &... | Answered on Jun 27, 2020
Who put it on your vehicle? They are normally there for a reason!
Removal video in the link
https://www.google.com/search?q=trax6-a+passtime
Car Audio &... | Answered on Jun 26, 2020
You posted to the category 'Car Audio'. This illustrates the problems of not stating
make model (what it is)
Vidpro XM-40 Condenser Shotgun Video ... - Amazon.com
www.amazon.com > XM-40-Condenser-Shotgun-Microphone-Windb...
Rating: 2.4 - ‎2 reviews
Amazon.com : Vidpro XM-40 Condenser Shotgun Video Microphone with Fuzzy Windbuster : Camera & Photo.
The '40s Junction ' SiriusXM Canada
www.siriusxm.ca > channels
'40s Junction. Hep Cats and Swingeroos, here comes the Savoy Express. Crooners serenade, and harmony groups join forces with orchestras to play ...
XM-40 Condenser Shotgun Video Microphone with Fuzzy ...
www.amazon.ca > Condenser-Shotgun-Microphone-Windbuster-Digital
XM-40 Condenser Shotgun Video Microphone with Fuzzy Windbuster For Nikon D300, D300s, D500, D3200, D3300, D600, D610, D700, D750, D800, D800e, ...
40s on 4 - The top music from the 40's on SiriusXM Radio
www.siriusxm.com > ...
Update Update. Add Channel to Favorites. 40s Junction. '40s Pop Hits/Big Band. Ch. 73 ... ET - XM Nine box icon Edit View. 12:00 am - 12:00 am '40s Junction.
Car Audio &... | Answered on Jun 19, 2020
Check your settings for Aux radio and for button reset the system.
Car Audio &... | Answered on Jun 17, 2020
On your Blaupunkt 520 player you can see the diagram .It should be like this
Thank You
Car Audio &... | Answered on Jun 13, 2020
A loudspeaker doesn't usually have DC present on the terminals due to the very low impedance a high current can flow and destroy the speech coil. It would also hamper the correct operation of the loudspeaker.
Because of this the amplifier output is decoupled either by transformer or by capacitor, effectively blocking direct current while allowing the alternating current output of the amplifier to pass.
The thump sound in the speakers at switch on is caused by the decoupling capacitors charging due to the speaker providing a ground path.
Purely as a matter of interest, in the days of ancient radio, some speakers had no magnet which was replaced by an electromagnet through which the radio supply current would run after rectification and smoothing, the windings acting as a smoothing choke providing additional regulation. Such loudspeakers had four terminals, two of which did carry a powerful direct current and those confusing the terminals quickly saw smoke...
Car Audio &... | Answered on Jun 12, 2020
It's protecting itself from a wiring short. There is a way to reset it but I can't remember the two buttons you hold down. I remember that first you have to disconnect the power and before turning on you push and hold two buttons the 3 and 6 continue holding when you power on radio.
Car Audio &... | Answered on Jun 09, 2020
English version operation manual
Car Audio &... | Answered on Jun 04, 2020
Blue light is an indicator of being damaged or crashed, check your MRP.
Car Audio &... | Answered on Jun 03, 2020
Ultra Linear UL801 Car Amp Logo
1 questions posted
Top Ultra Linear Car Audio & Video Experts
Marvin
Marvin
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Ultra Linear Car Audio & Video
Most Popular Question
amp
  • Car Audio & Video
