20 Most Recent Panasonic LUMIX DMCZS7 DMCTZ10 Digital Camera Questions & Answers
Does it work at all? Can you see a picture that you have taken with it?
If nothing at all the screen is fubar. If it works on playback only then the issue lies with the camera electronics.
If camera out of warranty usually not cost effective to repair.
Panasonic LUMIX... | Answered on Mar 06, 2016
To clarify: Using the Travel date will not show the date stamp on the photo on this camera as it does on other cameras. The date (as mentioned in the most recent post), will only show in the EXIF data.
Panasonic LUMIX... | Answered on Aug 31, 2014
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Panasonic LUMIX... | Answered on Jul 10, 2014
To make sure it has nothing to do with your camera, Try to put it in automatic mode. Most of the time, people switch to a mode the don't need at the moment, Or forgot they did use a scene mode last time the used the camera. When the camera is in the automatic mode, check the manual, in what situation you could improve the quality of the picture with what setting. Like freeze a movement in time with shutter prio, Or how to play with depth of field with the aperture.
Panasonic LUMIX... | Answered on Jun 06, 2014
We recommend you test a different PC or a different SD card reader. If you can view the photos on the camera the card is good.
Panasonic LUMIX... | Answered on Apr 21, 2014
On the CD that came with your camera, was not only the instruction manual, but also the software to get the pictures and videos from your camera on the computer.
You first have to install the software, than connect the camera and then you can copy the content from your camera to the computer. The software also helps you when you want to do some editing on pictures and or video.
If you don't have the CD, you can get the content to the computer with an external memory card reader. But still when you have the video on your computer it won't be usable on every apparatus.
For some players, you first have to convert the video to the format the player accepts.
To convert the video, there are several freeware convertors, that work very well. On my windows machine I use Potplayer on the mac I use VLC. Not sure it that program can convert, but i'm sure I can play (almost) every video format.
Panasonic LUMIX... | Answered on Jan 24, 2014
Use the "Copy" command to copy the photos from the internal memory to the memory card. Then you can download them from the memory card as usual. See page 137 of the Advanced Manual: http://www.fixya.com/support/p1363715-panasonic_lumix_dmczs7_dmctz10_digital_c/usermanual-17D5735-PDF
Panasonic LUMIX... | Answered on Jan 04, 2014
Your MAC can't show you every known video format. Look what format is on the camera and when you put the correct software on the MAC (that came with the camera on CD or DVD) you will be able to import and transfer the video's to the format your MAC can show.
Panasonic LUMIX... | Answered on Nov 30, 2013
How do you normally download your photos? If you do it by connecting the camera to the computer's USB port, simply remove the memory card before making the connection.
If you do it by taking the card out of the camera and putting it into a card reader, transfer the pictures from the camera to the card by using the Copy command in the Playback menu. See page 137 of the Advanced Manual: http://www.fixya.com/support/p1363715-panasonic_lumix_dmczs7_dmctz10_digital_c/usermanual-17D5735-PDF
Panasonic LUMIX... | Answered on Oct 19, 2013
bad drivers... update from manufacturers site or microsoft's windows update site
Panasonic LUMIX... | Answered on Oct 18, 2013
Go to E-Bay and search your cameras make and model and they sell a special jacket that the camera fits inside to protect it from the elements.
Panasonic LUMIX... | Answered on Jan 25, 2013
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Panasonic LUMIX... | Answered on Sep 23, 2012
Panasonic LUMIX DMCZS7  DMCTZ10 Digital Camera Logo
100 questions posted
Top Panasonic Cameras Experts
STEVE SPAM REMOVER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
camera indicates connected computer but
  • Cameras
