20 Most Recent FUJIFILM FinePix JZ300 Digital Camera Questions & Answers
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
FUJIFILM FinePix... • Answered on Oct 07, 2014
Hello zakera begumme too had the same problem. If you wanna fix it up,you should replace your LCD screen.But be happy, it only affects the screen but not the pictures. :-)It wont take much for a LCD replacement.
FUJIFILM FinePix... • Answered on Aug 21, 2013
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
I have had success with this camera recovery software... Download the program http://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
FUJIFILM FinePix... • Answered on Feb 15, 2013
Check if your device, conectted with USB cable at pc) is read and detected for the PC explorer program. If yes, just copy/paste your files.
Its possible that you need to re-install digital camera software or look for some Fujifilm upgrade.
FUJIFILM FinePix... • Answered on Oct 04, 2011
You as a consumer can not get that out. If it is not effecting the picture quality don't worry about it. If it is really driving you crazy you will need to take it to a reputable camera shop for cleaning.
FUJIFILM FinePix... • Answered on Jul 18, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
FUJIFILM FinePix... • Answered on May 09, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
How to easily download Pictures from Digital Camera
heatman101
FUJIFILM FinePix... • Answered on Apr 28, 2011
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
FUJIFILM FinePix... • Answered on Apr 11, 2011
this is the only thing i found by reading the manual
registering a name
  1. press the selector up and down to highlight NAME in PERSONAL INFO
  2. Press MENU/OK to display NAME window/press MENU/OK to display BIRTHDAY
  3. Input the date of birthday in the same way as setting DATE/TIME
  4. Press MENU/OK to register
hope this helps!
FUJIFILM FinePix... • Answered on Apr 07, 2011
Are you check in the user guide...
FUJIFILM FinePix... • Answered on Mar 03, 2011
Press MENU/OK to bring up the menu. Use up/down to select SET (the wrench icon), then press right to activate the setup menu. Select DATE/TIME and press right.
FUJIFILM FinePix... • Answered on Feb 08, 2011
You can download a copy from the manufacturer's web site at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/j/finepix_jz300_manual_01.pdf
FUJIFILM FinePix... • Answered on Nov 08, 2010
You can download and print the owners manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps you. Thanks for using FixYa.
FUJIFILM FinePix... • Answered on Oct 15, 2010
The manual for your camera is found here:
http://www.fujifilm.com/products/digital_cameras/j/finepix_jz300/
In the right column, you can find a link to the pdf user's guide, below the catalogue. The manual is 100+ pages long, so you should have more than enough information.
FUJIFILM FinePix... • Answered on Jul 21, 2010
This is not a camera - it appears to be some kind of office equipment. Posting your query in a forum dealing with such items may help.
FUJIFILM Cameras • Answered on Mar 18, 2020
FUJIFILM FinePix JZ300 Digital Camera Logo
26 questions posted
Top FUJIFILM Cameras Experts
Falling star
Jax Planet
Jax Planet
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
View Most Popular
FUJIFILM Cameras
  • FUJIFILM Cameras
Most Popular Question
just noticed dust behind
  • Cameras
