20 Most Recent
Optoma EP737 - DLP PROJECTOR - 1500 LUMENS *NIC* Multimedia Projector Questions & Answers
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Optoma DLP projector EP 731
This sounds like an LCD shading problem. Optoma or an authorized service technician will need to replace the LCD filter.
Lcd proctor image
Disconnect the computer and then run projector if it still comes then service your projector.
Viren
Optoma ep 753 will not light
you can just open the lamp and see the condition of the inner tube only. otherwise you have to replace the lamp and run it.
Viren
+919814903739
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
