20 Most Recent
Optoma EP732H EZPRO DIGITAL PROJECTOR Multimedia Projector Questions & Answers
How do I find the remaining bulb life for the
There is not a set time for bulb life. The projector will have a timer built in to tell you how many hours it's been running. I've had projectors that I've reset the warning twice before I've noticed any performance issues with the bulb. That particular bulb has a life of approx 2000 hrs, so go through the menu on your projector and find the "lamp timer" or something similar to that and do some simple math. :)
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
I am trying to replace
The fixture and bulb are designed as one piece. When you order a new bulb it comes with the black fixture.
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
Optoma DLP projector
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
