20 Most Recent Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum Questions & Answers
3answers
I want to clean a
There is no other way to clean mattress except by using a vacuum cleaner. It is because when you use water in cleaning your mattress, this might start molds especially when the mattress layer has remains of moisture. If you want to have a stain free, spotless and moisture-free mattress, use a mattress pad. Or you may use a waterproof mattress pad to avoid unwanted stains in order to keep a clean mattress at all time. A waterproof mattress also protects your mattress against undesirable odor and has maximum protection ability. Click the below link to know more. How to Keep Your Mattress Clean by Moazzem Hossain
9/13/2019 11:44:29 AM • Kirby Shampooer... • Answered on Sep 13, 2019
How do I tighten a handle on an upright Kirby vacuum?
Your question isn't specific enough. The upper handle grip has a bolt through the upper cord wrap that can be tightened. The lower handle has 2 bolts, but they rarely get loose. If you're concerned with the way the handle wobbles side to side at the base, that's normal. If you want a better diagnosis, take it to your local vac shop to have it looked at.
2/19/2015 2:31:46 PM • Kirby Shampooer... • Answered on Feb 19, 2015
How do i put my sentria back together after changing band
see utube video for refitting
4/29/2014 10:51:51 AM • Kirby Shampooer... • Answered on Apr 29, 2014
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem. You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor. Amazon com Home Kitchen
1/30/2014 1:06:52 PM • Kirby Shampooer... • Answered on Jan 30, 2014
Zip code saudi arabia
you don't say what the problem is this link is the manual and video for kirby shampooerhttp://www.goodvac.com/Articles.asp?ID=153
4/25/2013 11:54:43 AM • Kirby Shampooer... • Answered on Apr 25, 2013
How do i replace the
Hello,Please see the instructional video hereGood Luck,Rocky
12/17/2011 6:25:38 PM • Kirby Shampooer... • Answered on Dec 17, 2011
It wont suds up. it just keeps shooting out soapy
Hello,Please see the detail instructional video hereBest regards,Rocky
12/17/2011 6:23:50 PM • Kirby Shampooer... • Answered on Dec 17, 2011
Where can I get a free manual download for a
Hello,This manual will answer all the questions.Good Luck,Rocky
12/17/2011 6:21:28 PM • Kirby Shampooer... • Answered on Dec 17, 2011
Put the transmission back in?
Hello,See if this manual will help HERE.Good Luck,Rocky
12/17/2011 6:11:48 PM • Kirby Shampooer... • Answered on Dec 17, 2011
My wife took the vacuum apart and now the
The small screen goes on the outlet of the soap tank.
6/18/2011 3:58:22 PM • Kirby Shampooer... • Answered on Jun 18, 2011
0answers
I'm trying to use the blower part to blow up a
hi
study how the bag attaches to the machine. usually you turn that bag collar a quarter turn counterclockwise to get that collar off. get ready because dirt will get all over.. then hook the larger end of the hose to where you just took that off. one of those smaller attachments that came with it goes on the other end of the hose to attach it to the mattress or use a small funnel or a straw and duct tape..
jm
4/30/2011 5:40:29 AM • Kirby Shampooer... • Answered on Apr 30, 2011
0answers
Can't figure out how to
The below link is to a Kirby site that provides a video for attaching the shampooer. Very informative.
http://www.kirby.com/Portals/0/videos.html
1/23/2011 4:23:55 PM • Kirby Shampooer... • Answered on Jan 23, 2011
It wont turn on at all
There is a switch that prevents the motor from running unless the shampoo tank, (or bag assembly) is fully installed. Be sure the tank is tight against the side of the machine, and not blocked by the cord, The shampoo head must also be fully attached.
1/19/2011 9:40:29 PM • Kirby Shampooer... • Answered on Jan 19, 2011
Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum Logo
32 questions posted
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
tighten handle upright kirby vacuum
  • Vacuums
