20 Most Recent
Dyson DC16 Animal Bagless Handheld Cyclonic Vacuum Questions & Answers
When I push the power button on my dc16 animal
Hey Josh. According to the manual I found at this URL:
http://media.dyson.com/downloads/us/floorcare/manuals/dc16_opmanual_usa.pdf
the red light that comes on when you try to use the unit indicates that the battery is fully discharged.
When you plug the unit in to charge it, the same red light should be blinking to indicate the battery is in the process of charging.
Take a look at this and let me know if you are still having issues with the unit running, as there might be a problem with the wiring from the battery to the motor.
Paul
What size Torx screwdriver do I need to fix a Dyson V8
You ONLY need a T15 for these models DC01, DC02, DC03, DC04, DC05, DC07, DC08, DC14, DC19 and DC25.
If you are going to be working on models such as the the DC24 and other later Ball machines like the DC15 and DC18, and newer machines like the DC39, DC40 and DC41, not to mention new Cinetic machines, you will also need a T10 with an anti-tamper end and also a T8 for some jobs.
If you are planning to repair later models, get a T8, T10 T and the T15 T (The extra "T" denotes anti-tamper).
My dyson dc25 got over full and just stopped working. It turned on with half power but wouldn't sick anything up and now won't turn on at all. Please help.
Here are a few steps you can try to troubleshoot the problem:
- Check the filter: Make sure that the filter is clean and that there is no blockage in the filter.
- Check the bin: Make sure that the bin is empty and that there is no blockage in the bin.
- Check the brush bar: Make sure that the brush bar is not clogged with hair or debris.
- Check the hose: Make sure that the hose is not clogged or blocked.
- Check the motor: Make sure that the motor is working properly.
- Check the power supply: Make sure that the power supply is working properly and that the vacuum cleaner is properly plugged in.
- Consult the manual: Consult the manual for specific troubleshoot and service information for your Dyson DC25 vacuum cleaner model.
Dyson Ball Cleaner Head suction stops when head is attached; Multi Floor 2; UP19
If the suction on your Dyson Ball Cleaner Head stops when the head is attached, it could be due to a problem with the head itself or with the vacuum's hose and wand. Here are a few things you can try to troubleshoot the problem:
- Check the hose and wand for any blockages or kinks. Remove any blockages or straighten out any kinks to restore suction.
- Check the hose and wand for any visible damage, such as holes or cracks. If the hose or wand is damaged, it will need to be replaced.
- Check the connection points between the hose, wand, and cleaner head to make sure they are secure and not loose.
- Check the filters to make sure they are clean and not clogged. If the filters are dirty or clogged, they can reduce suction.
- If the problem persists after trying these troubleshooting steps, you may need to take the vacuum to a repair center for further diagnosis and repair.
I hope this information is helpful! Let me know if you have any other questions.
Dyson dc24 no suction from hose
If your Dyson DC24 vacuum has no suction from the hose, it could be due to a blockage or a problem with the hose itself. Here are a few things you can try to troubleshoot the problem:
- Check the hose for any blockages or kinks. Remove any blockages or straighten out any kinks to restore suction.
- Check the hose for any visible damage, such as holes or cracks. If the hose is damaged, it will need to be replaced.
- Check the hose connection points to make sure they are secure and not loose.
Dyson v11 motor not smooth
if the calibration steps (often) recommended by the manufacturer do not work, please switch outlets and monitor performance of the motor from the different power source. If this fails, then you might next swap your current motor with another one from ebay or alixpress and test the vacuum again with the substituted motor.
Thank you.
Why does my Dyson D43 dust canister not snap into place?
I also have a dyson vacuum but it is an old version. I have been having that problem recently and i researched the internet about the similar subject. People are having so many complains about the release button . Hopefully you will solve it by calling the service to replace it with a new dyson. Otherwise the problem you are having will continue
good luck??
My Dyson DC75 Brush is constantly spinning and will not turn off.
it sounds like the vacuum has received too much power at one time. If you've left it plugged into an outlet that varies in voltage or current from the standards of the vacuum, this might be the cause. You might need to use a connecting cord (that acts like a reverse outlet) to suck the excess power out of the vacuum and into a mobile battery/capacitor. This allows you to save any energy removed from the vacuum.
Thank you.
Dyson V6 leaves rubber marks on hardwood floor, all the wheels are free spinning so what do I do
If you had rolled it through some kind of petroleum based solvent like acetone, gasoline, kerosene, benzene, diesel fuel or, sometimes, alcohol, you may have converted the rubber tires into something akin to bubblegum. If you turn it upside down and feel them, check to see if they are sticky or gooey. If so, you'll have to replace them. Good luck.
